White LT-125 problems
8 replies to this topic
#1 dogsoldier OFFLINE
dogsoldier
  • 361 Thanks
  • 509 posts
Posted April 28, 2015 - 02:02 PM
i was given a white lt 125 hydro
the rear end seems like its locked up.
 i released the pressure by the lever
nothing.
also when i try and start it i get a clicking from the solenoid
but the starter does nothing.
when i tap the starter with a jumper cable
it just sparks and nothing else.
i would say the starter is bad. correct ??
on the up side it comes with a bagger  system
which i may try to hook up to the yard machine
#2 Bud W OFFLINE
Bud W
  • 326 Thanks
  • 303 posts
Posted April 28, 2015 - 02:09 PM
Make sure the engine / hydrostatic are not stuck (turns over).
#3 dogsoldier OFFLINE
dogsoldier
  • 361 Thanks
  • 509 posts
Posted April 28, 2015 - 02:11 PM
i can turn the motor by hand with no problems
#4 Bud W OFFLINE
Bud W
  • 326 Thanks
  • 303 posts
Posted April 28, 2015 - 02:55 PM
It sounds like you have a bad starter.
#5 boyscout862 ONLINE
  • 12,869 Thanks
  • 9,180 posts
Posted April 28, 2015 - 03:05 PM
Before you change the starter, check the engine and starter grounds. Good Luck, Rick
#6 glgrumpy ONLINE
  • 8,622 Thanks
  • 7,926 posts
Posted April 28, 2015 - 05:14 PM
Is there a two-speed by chance?  Maybe it is caught between gears on lever?  PB blast stuff and get working right, then try to turn. Hard to imagine hydro being locked up, to me at least.  Check brakes on it too. If a disc on side, they sometimes just rust up and get stuck, or drums can be even worse if swelled liner in those. For jumping, use good cables, too long of ones makes for same issues as a weak battery many times.  Try a new battery first?
#7 dogsoldier OFFLINE
dogsoldier
  • 361 Thanks
  • 509 posts
Posted April 28, 2015 - 07:10 PM
I just went out to check the brake out and the peddle moves way to easy.
I'm going to have to wait till the weekend to check it out more.
While I was out there I took a few pics
uploadfromtaptalk1430266062370.jpg uploadfromtaptalk1430266105916.jpg uploadfromtaptalk1430266147046.jpg uploadfromtaptalk1430266187360.jpg
#8 glgrumpy ONLINE
  • 8,622 Thanks
  • 7,926 posts
Posted April 28, 2015 - 08:31 PM
This might sound dumb, but I had similar looking rig that acted locked up, could turn by hand some  on engine. Come to find out the BELT was just rusted into the pulleys and was loose for partial turn, then grabbed hard where it was rusted.  Check the rear pulley on trans also for same.  This small size probly has disc brake and pedal may still move and pull springs and such and not really set brake or release. Pull the belts, take off wheels to see and try to work the top pulley on trans and see if movement. Body off would be nice too, but probly quite a job to remove??  Have had drives only on those briggs starters jamb and be stuck in place on flywheel or ropes or junk wrapped around the same drive and not allowing it to come back off.
Edited by glgrumpy, April 28, 2015 - 08:33 PM.
#9 dogsoldier OFFLINE
dogsoldier
  • 361 Thanks
  • 509 posts
Posted May 14, 2015 - 08:18 AM
got a chance to look at the white yesterday
i could turn the belt by hand , it has no resistance at all
so not sure why it wouldnt roll. when i tried to
push it , it rolled with no problems at all.
so now ill put a battery in it and try to get it started.
