MTD 800 needs new motor
has 18hp want 25hp
4 replies to this topic
#1 metro-mike OFFLINE
metro-mike
  • 2 posts
Posted April 28, 2015 - 11:14 AM
   I have a 800 series garden tractor which I have had since new. The B&S motor has been going south the last few years and I was looking to get another motor, hopefully with more hp.
  MTD 800 18hp B&S 46" cut, 12 speed Hi/Lo
   Model 422707
   Type 121401
   Code 9405105B
     Any ideas on where to get another motor that would fit my current tractor?
                  Thanks for any ideas or directions.
#2 boyscout862 OFFLINE
  • 13,559 Thanks
  • 9,433 posts
Posted April 28, 2015 - 11:19 AM
Welcome to GTT. The engine may just need an overhaul. We would need more info on the particular engine you have and pics will clarify. A new engine will have to match the electrical system of your tractor. Check out our Manuals Section for the manuals that you need. Good Luck, Rick
#3 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted April 28, 2015 - 10:32 PM
Welcome to the forum!
What in particular is wrong with your old engine?
The bad part about those old opposed engines is that it is hard to find a replacement v twin made now that will fit without chopping and slicing.    Briggs doesn't even suggest any replacements, and Kohler and Kawasaki don't even list an option.  That doesn't mean there isn't one, it just means that nothing made today is going to fit that footprint 100%.
Almost all the parts you need are available for those old Briggs, and you will be hard pressed to find a better engine.
Ben W.
#4 metro-mike OFFLINE
metro-mike
  • 2 posts
Posted April 29, 2015 - 10:55 AM
The motor is a vertical shaft twin and the lower main seal has been leaking/dripping on to the main belt.  The engine gets real low on power as it warms up to operating temp.
Guess I'll look for some parts.  I was hoping to put a larger hp motor in the frame that included a oil filter.
#5 Gabriel OFFLINE
Gabriel
  • 1,448 Thanks
  • 1,863 posts
Posted April 29, 2015 - 09:07 PM
Welcome to GTTalk!
