Free Wheeling Not Alway Free
4 replies to this topic
#1 chieffan ONLINE
  • 16594 Thanks
  • 9088 posts
Posted April 27, 2015 - 06:35 PM
Have a 1050 that the transmission wants to hang up when free wheeling.  The pin is out and clear of the hub. Gear shift is in neutral.  Lot of times it will roll forward but when it starts to come back it stops dead.  Worse when front wheels are turned.  Differential lock hub has been removed, cleaned and back together with no pressure.  No difference. Going straight back is usually fine but when you try to turn the wheels it will stop the back wheels dead.  If you  hold the clutch down it is OK.  When running the gears all work like they are supposed to.  Any idea as to what is causing this situation ? ?
#2 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted April 27, 2015 - 06:39 PM
Have you ever adjusted your rear axle end play?
  • boyscout862, superaben and chieffan have said thanks
#3 chieffan ONLINE
  • 16594 Thanks
  • 9088 posts
Posted April 27, 2015 - 06:55 PM
NO. Have not got that far on it yet. Just got it running right today. Would excess end play cause the free wheeling to bind up?
#4 Bruce Dorsi ONLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 5122 Thanks
  • 2911 posts
Posted April 27, 2015 - 07:09 PM
Yes, it can.
  • Bolens 1000 and chieffan have said thanks
#5 chieffan ONLINE
  • 16594 Thanks
  • 9088 posts
Posted April 28, 2015 - 07:01 AM
Thanks guy.  Have to pull the motor in the G16 this morning to get at the starter and drive shaft.  Will try and get the axel end play taken care of after that little chore.
