what do you guys think of this one?
16 replies to this topic
#1 toomanytoys84 ONLINE
toomanytoys84
    Aaron
  • 10,878 Thanks
  • 6,358 posts
Posted April 27, 2015 - 10:58 AM
Any advice?
Going to check it out this weekend I think if it doesn't sell before then.
  • 101 senior, hamman, Lmiller3358 and 2 others have said thanks
#2 jimbobbillyray OFFLINE
jimbobbillyray
  • 3,174 Thanks
  • 2,941 posts
Posted April 27, 2015 - 11:39 AM
Nice tractor, great condition.   It's a surprise to me..I.didn't know they made a 10 hp. Suburban. All I've seen are 12hp.    The color suggests it is a '67-'68.  Orange and white were points motors if I remember right...not the SSi ignition.
  • Lmiller3358 and toomanytoys84 have said thanks
#3 chris m OFFLINE
chris m
  • 3,341 Thanks
  • 4,065 posts
Posted April 27, 2015 - 12:04 PM
It looks great! If it runs as good as it looks and the price is right, I would buy it. Especially if it was a points engine that runs.
Up here people would want a lot for it (IMO) If it is as good as it looks I would be willing to spend $300
Good luck!
#4 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted April 27, 2015 - 12:07 PM
That's a really nice Sears.
  • 14,889 Thanks
  • 15,514 posts
You have $100.00 just in the Ags and that's being conservative.
Well worth $300.00 in my book.
#6 Lmiller3358 OFFLINE
Lmiller3358
  • 1,547 Thanks
  • 1,458 posts
Posted April 27, 2015 - 12:11 PM
That would be a 67 SS10
  • rustyoldjunk and toomanytoys84 have said thanks
#7 toomanytoys84 ONLINE
toomanytoys84
    Aaron
  • 10,878 Thanks
  • 6,358 posts
Posted April 27, 2015 - 12:12 PM
I think its actually a 67.  He has it listed as a 68 SS12
Edited by toomanytoys84, April 27, 2015 - 12:31 PM.
  • rustyoldjunk said thank you
#8 toomanytoys84 ONLINE
toomanytoys84
    Aaron
  • 10,878 Thanks
  • 6,358 posts
Posted April 27, 2015 - 12:13 PM
He wants 600 for it.  I haven't seen it yet.  He said it won't idle without half choke, but runs perfect at full throttle.
Sounds like a typical Tecumseh carb to me.
It is a points engine, he confirmed that to me through text messages
He also has the belt guard.
Anyway to put a better seat on it?  That thing looks uncomfortable..
How do these cut?  Looking for a good finish cut.  I am a cub cadet guy, no experience with the Suburban
Edited by toomanytoys84, April 27, 2015 - 12:15 PM.
  • jimbobbillyray said thank you
#9 propane1 ONLINE
propane1
  • 9,469 Thanks
  • 4,395 posts
Posted April 27, 2015 - 04:02 PM
Nice tractor, looks good. Must of had a very hilly yard or had a snow thrower at one time, because of the ag tires and chains. Noel
#10 MH81 OFFLINE
  • 29,979 Thanks
Posted April 27, 2015 - 04:21 PM
They cut decent enough, not sure how it would stack against a Cub.
Verify center axel bolt pivot slop. Known issue, fixable.
Look for thin spots in that deck (looks like a quickie paint job... Why?)
Listen for bad bearings in the deck.
The seats are a lot more comfy than you would think, but yeah... Lots of aftermarket ones will work.
IMHO, 600 is way high. If it was a perfect runner, with no issues, and needed nothing, maybe 350-400. The four being a points engine vs a CDI.
This isn't a Wheel Horse, JD, or an O.. It's a sears, and they made a BUNCH of them.
  • chris m and toomanytoys84 have said thanks
#11 toomanytoys84 ONLINE
toomanytoys84
    Aaron
  • 10,878 Thanks
  • 6,358 posts
Posted April 27, 2015 - 05:05 PM
Thanks mh81 great advice
Might not be worth an hour drive if he isn't going to down on price. I could put that 600 into fixing up the extra cub 128 I have sitting.
Edited by toomanytoys84, April 27, 2015 - 05:34 PM.
#12 67SS12 OFFLINE
67SS12
  • 22 Thanks
  • 17 posts
Posted April 27, 2015 - 07:34 PM
Nice tractor. 67 Suburban 10. No such thing as a SS10. $350-$400. Running issue could be a simple as the points gap. My SS12 runs funny when the points are not set right.
#13 rustyoldjunk OFFLINE
rustyoldjunk
    Has anybody seen my coffee ?
  • 2,643 Thanks
  • 1,318 posts
Posted April 27, 2015 - 11:40 PM
I would guess you can thank old ethanol gas for plugging up the carb making it need some choke to run. My two cents. I like my Sears better than JD by far,as good my Wheel Horses (and I'm a Horse nut),and better than Cub. IMHO value is just as high as any of the above because they are well built good running,driving tractors with so many attachments readily available and BECAUSE there is so many of them out there. It makes parts plentiful to keep your tractor going.
Edited by rustyoldjunk, April 27, 2015 - 11:40 PM.
  • MH81 and toomanytoys84 have said thanks
#14 olcowhand OFFLINE
  • 42,898 Thanks
  • 31,941 posts
Posted April 28, 2015 - 07:03 AM
An early 67 HH100 can have points, while late 67's can have solid state ignition.  My 67 Massey MF12 has points, and late 67 MF12's had solid state.
#15 TAHOE OFFLINE
TAHOE
  • 8,309 Thanks
  • 5,803 posts
Posted April 28, 2015 - 11:45 AM
Nice tractor, definitely a 67 if it's a10hp, not 600 nice though. 400 tops to me.
Carb is probalby plugged with junk, needs a good cleaning. Notorious for play in choke and butterfly rod bushings also.
I cut with mine, 42" deck. Not impressed with cut, kind of dismal IMO. If you want a super cut from a GT, buy a SImplicity or AC, none match in my book.
Daniel you are correct somewhat, Sears started converting to SSI in late 67, but mostly on the 12 HP SS12 models, I thnk most 10's stayed with points.
