Tri-Trac with middle buster installed
8 replies to this topic
#1 Alc ONLINE
  • 6,884 Thanks
  • 7,459 posts
Posted April 26, 2015 - 08:19 PM
I thought I would try a different attachment on the Tri-Trac , I had the sickle bar and moldboard plow. I was hoping to put the 2 row planter but but when I tried you have to widen the front axle for clearance and  at that setting it wouldn't fit my trailer ( only 5' x 10'  ) so I put the front lift on which is also used for the cultivator .  2 pins on each side holds either attachment to the lift . I tried it in the garden and not really should why you would even use because the rear tire packs down right where you just plowed ? I have the colter wheel but since it was never used ( still has the shipping wires attached )  I'll just take it to the shows just to display .
  • rustyoldjunk, Gtractor, MH81 and 9 others have said thanks
#2 chris m OFFLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted April 26, 2015 - 08:26 PM
I like it! I wounder when used for potatoes, if it will move them far enough away so the tractor doesn't run them over?
#3 Alc ONLINE
  • 6,884 Thanks
  • 7,459 posts
Posted April 26, 2015 - 08:46 PM
I'm not sure , it's pretty wide. Not sure if they recommended that use .I'll look through the manual to see if anything is mentioned
  • chris m said thank you
#4 MH81 OFFLINE
Posted April 26, 2015 - 08:50 PM
Looks really ready to dig taters to me!
Cool piece, bet they're not common.
#5 WHdbJD ONLINE
WHdbJD
  • 686 Thanks
  • 516 posts
Posted April 27, 2015 - 05:07 AM
wow, never saw a middle buster for TriTrac!
#6 Alc ONLINE
  • 6,884 Thanks
  • 7,459 posts
Posted April 27, 2015 - 05:20 AM
I wanted to put something different this time , really wanted the planters but that didn't work out this time . With this frame it will be easier to put the cultivators on ,,then just the single one that mounts right behind the rear tire which does where the tire tracks .
#7 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted April 27, 2015 - 07:34 AM
I want a Tri-Trac!
#8 KennyP ONLINE
  • 38,329 Thanks
  • 45,913 posts
Posted April 27, 2015 - 10:01 AM
Looks good on there, Al!
#9 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted April 27, 2015 - 10:40 AM
That does look like it means business Al.  I was hoping for some action photos!
