Sears custom 10E Oooops
9 replies to this topic
#1 EricFromPa ONLINE
EricFromPa
  • 3,658 Thanks
  • 3,113 posts
Posted April 25, 2015 - 05:16 PM
Well I finally got the time to finish rebuilding the HH100 on the sears.Got it to run perfect with 1 exception.
Well here easier to show than explain.I just ordered a NOS one for $12 shipped they are NLA parts so i gota be more carefull when I put it back together this time.
There was a very slight bind when I put the bearing cover back on.I just tightened the bolts and didn't think about it.Well I won't be doing that again hopefully.
  • tinbender7, chris m and boyscout862 have said thanks
#2 EricFromPa ONLINE
EricFromPa
  • 3,658 Thanks
  • 3,113 posts
Posted April 25, 2015 - 05:17 PM
I could of welded it with the Mig but don't want to take the chance of it coming apart inside the engine.
  • KennyP, tinbender7 and chris m have said thanks
#3 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted April 25, 2015 - 06:00 PM
What is it?
#4 craftsmanmowerfreak ONLINE
craftsmanmowerfreak
  • 288 Thanks
  • 232 posts
Posted April 25, 2015 - 06:11 PM
governor arm?
#5 chris m OFFLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted April 25, 2015 - 06:47 PM
governor arm?
You are correct :thumbs:
  • superaben said thank you
#6 chris m OFFLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted April 25, 2015 - 06:49 PM
Sorry it happened! At least it didn't do any other damage.
We have all had our Oooops moments! Glad you where able to find one! Good luck with it.
#7 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted April 25, 2015 - 07:21 PM
Don't be embarrassed, it is a pretty common mistake.  I've sold a whole pile of those things as a result, too.
Ben W.
  • Bolens 1000 and EricFromPa have said thanks
#8 craftsmanmowerfreak ONLINE
craftsmanmowerfreak
  • 288 Thanks
  • 232 posts
Posted April 25, 2015 - 07:43 PM
i had to replace one in a briggs before because of the grove in it from governor
#9 EricFromPa ONLINE
EricFromPa
  • 3,658 Thanks
  • 3,113 posts
Posted April 25, 2015 - 08:36 PM
Hey other than that it runs AWESOME now.I had to put a new rod and a set of rings in it before it decided to let go.It was starting to smoke pretty good and had a noticeable knock.Both rod nuts were extremely loose and the Oil was black and smelled nasty.Nothing like the smell of cheap Burnt wallmart Hi-Tech recycled oil.Here's the Rod I took out of it.Crank had no sign of wear or galling which is amazing.
Guess I caught it Just in the nick of time.
No I'm not the one that used that cheap crap oil in it.I am a cheap arse but not THAT cheap. :rolling: I use Shell Rotella T1 30W in my stuff.
Edited by EricFromPa, April 25, 2015 - 08:40 PM.
#10 EricFromPa ONLINE
EricFromPa
  • 3,658 Thanks
  • 3,113 posts
Posted April 25, 2015 - 08:43 PM
Ben W.
Do you still have them in stock? Ummm Just in case :rolling:
