LX188 wiring diagram need.
5 replies to this topic
#1 KenM OFFLINE
KenM
  • 50 Thanks
  • 131 posts
Posted April 25, 2015 - 02:25 PM
I am In need odd an lx188 wiring diagram. No crank but will start and run if you jumper the starter. Pretty sure it is the switch. But wanna rule everything else out first.
  • Traill95 and larisaPn have said thanks
#2 WNYTractorTinkerer OFFLINE
WNYTractorTinkerer
    Tinker Master
  • 11,245 Thanks
  • 6,065 posts
Posted April 25, 2015 - 03:28 PM
JD information is out there but the company discourages sharing it.  For giggles try a dealer and when he tells you that you will need a $150 repair manual don't be surprised.Perhaps someone will have what you need and chime in..
Brake or Neutral switch and PTO switch are the usual JD interlocks to start a tractor..
There may be a Safety relay in there as well.  The best way is to chase down the Start wire from the Ignition switch and with the PTO off and the parking brake set test for voltage along the path down to the solenoid.  This is the best way to trouble-shoot your problem.  A 12v test light works well here and another set of hands is nice if you can..  :goodl:
#3 Traill95 ONLINE
Traill95
    Traill95
  • 1,858 Thanks
  • 1,020 posts
Posted April 25, 2015 - 04:47 PM
When you need parts for that 188 I have a Kawasaki 17hp  water cooled motor and hydro rear end off of one plus assorted other parts.
  • KenM said thank you
#4 KenM OFFLINE
KenM
  • 50 Thanks
  • 131 posts
Posted April 25, 2015 - 04:50 PM
Do you have any 48" deck parts for the lx188 or whatever else they fit.
Edited by KenM, April 25, 2015 - 05:45 PM.
  • Traill95 said thank you
#5 Traill95 ONLINE
Traill95
    Traill95
  • 1,858 Thanks
  • 1,020 posts
Posted April 25, 2015 - 06:53 PM
Already sold the deck off of it.
#6 KenM OFFLINE
KenM
  • 50 Thanks
  • 131 posts
OK.
