DIY Bolens TubeFrame Sleeve Hitch
3 replies to this topic
#1 Sawdust OFFLINE
Sawdust
  • 5,563 Thanks
  • 3,335 posts
Posted April 25, 2015 - 10:33 AM
I know we have had several of these made recently & being inspired by this I thought of making one myself. This will be for my H16.
Mine started out as some scrap that had been used to make road barriers a friend gave me years ago. I cut it down to workable material & flattened out the long piece that was bent.
I laid out the marks for cutting 2/3rds through the flat stock for bending later. The drawing that I used had ID of the long legs of the hitch tight against the insides of the axle flanges of my tractor. This measurement was 10 7/8ths. The nose of the hitch was 5" so I added another 1/4" to this making it 5 1/4" wide. This will spread the legs apart to give me 11 1/8th wide. Doing this will allow the long legs of the hitch to lay exactly in the middle of each axle flange area to work up & without rubbing against the flange.
I first made a cut 2/3rds through the flat stock with an angle grinder using a metal cutting disc. I then took a metal grinding disc & made a V cut along this line. When the grinding disc cuts for a few minutes it develops a nice V shape that cuts a perfect angle for bending.
Its raining today so next I will weld up all the cuts then cut the other pieces. Thanks for looking!
  • pharmer, boyscout862, KC9KAS and 2 others have said thanks
#2 pharmer OFFLINE
pharmer
  • 871 Thanks
  • 774 posts
Posted April 25, 2015 - 03:19 PM
Wow...it's like you're in my head. I'm actually in the process of doing that same exact thing.
  • Sawdust said thank you
#3 sodisr OFFLINE
sodisr
  • 663 Thanks
  • 773 posts
Posted April 26, 2015 - 11:49 AM
Looking good....   That's how I did mine...
#4 Little Irish Men OFFLINE
Little Irish Men
  • 817 Thanks
  • 468 posts
Posted April 27, 2015 - 07:23 PM
Is there any way that your pic and info can be pinn or save for a down load on the manuals ?  . . I think that is a darn good way to make a sleeve hitch.
Patrick.
