Homemade Box Blade
6 replies to this topic
#1 jdslednut OFFLINE
jdslednut
  • 680 Thanks
  • 851 posts
Posted April 25, 2015 - 12:36 AM
Been spending some time when the kids aren't using the equipment to fab up a box blade.  Currently I have it set up for use with my sleeve hitch on my JD 314 but have plans to make it into a 3 point connection.  That is if I can find a reasonable 3 point for my 314.  Gotta be ready just in case.  I found a round fender JD for a parent of one of my students and it came with a cobbled up front blade from a Cub Cadet.  He gave it to me as a "finder's fee" so I had to do something with it.  Any suggestions on improvements?  I just hope it works when I hook it up.
  • Gtractor, KennyP, boyscout862 and 2 others have said thanks
#2 shorty ONLINE
shorty
  • 5,839 Thanks
  • 5,421 posts
Posted April 25, 2015 - 05:50 AM
It looks like it should work. The improvement ideas will come as you use it. It appears that the hitch is in a sleeve. Is this so you can swap from sleeve hitch to three point?
#3 boyscout862 OFFLINE
  • 13,559 Thanks
  • 9,433 posts
Nice job.
#4 KennyP ONLINE
  • 40,986 Thanks
  • 47,152 posts
Posted April 25, 2015 - 06:18 AM
Looks good. How far below the sides is the cutting edge? I hope you can find that 3-point as this type will perform better when you tweak the top link.
#5 coldone OFFLINE
coldone
  • 1,664 Thanks
  • 1,683 posts
Posted April 25, 2015 - 06:23 AM
I got a sears front blade that just might be turned into one of those. Thats a great idea.
#6 jdslednut OFFLINE
jdslednut
  • 680 Thanks
  • 851 posts
Posted May 29, 2015 - 03:29 PM
Just about have it wrapped up.  I'll give the sleeve hitch a try and keep hoping to find a reasonable 3 point for my 314.
#7 tater195 OFFLINE
tater195
  • 2,264 Thanks
  • 1,443 posts
Posted May 29, 2015 - 03:36 PM
The only thing I see that might not work out is the flat stock on the bottom behind the blade. I think that will keep the blade from digging good. Most blades have a cutting edge back there for cutting
