Cleaning the nuts and bolts.
48 replies to this topic
#1 IamSherwood OFFLINE
  • 8,395 Thanks
Posted March 21, 2011 - 08:03 AM
When doing a resto, how do you tackle that part of the project?
It's a painful, tedious operation, but maybe it doesn't have to be.:wallbanging:
Post your method.
#2 jdslednut OFFLINE
jdslednut
  • 680 Thanks
  • 851 posts
Posted March 21, 2011 - 08:18 AM
I stick them in a carburetor cleaner soak, sometimes for 2 or 3 runs as the cleaner weakens.
#3 thecoater OFFLINE
thecoater
  • 13 Thanks
  • 111 posts
Posted March 21, 2011 - 08:58 AM
you can get a tumbler ,I have been eyeing a few but they get pricey
  • 14,884 Thanks
  • 15,514 posts
Posted March 21, 2011 - 09:43 AM
Has the tumbler worked for you, I have one and let some nuts and bolts run in it for two days,,, Didn't hardly scratch the surface rust..
#5 IamSherwood OFFLINE
  • 8,395 Thanks
Posted March 21, 2011 - 09:57 AM
I've been doing the hard way. In the vise with soft jaws, and a wire wheel, after degrease'g.
Sure would like to get away from that.
I've been trying to think of a way to do it in the electrolysis tank.
3 issues-keeping them sorted, line of sight coverage, and so many tiney alligator clips.
Nope, that's not the answer.
#6 Texas Deere and Horse OFFLINE
  • 14,884 Thanks
  • 15,514 posts
Posted March 21, 2011 - 10:08 AM
Could you wrap a copper wire or no.9 steel wire around them like they do when you chrome plate stuff?
Then you could hang all the wires from a common rod that is hooked to power..
#7 IamSherwood OFFLINE
  • 8,395 Thanks
Posted March 21, 2011 - 10:19 AM
I'm not sure if copper in there would be an issue.
How about a tray like an icecube tray, but larger, and made of steel sceen. Like screen door screening.(the good stuff)
Use a steel plate as the electrodes, and hang one under the tray, and one over.
May have to stir the hardware a few times.
It would take a bit to make the tray/basket so it's strong enough, but easily reusable.
I wonder if there is a beast out there like that.
#8 Texas Deere and Horse OFFLINE
  • 14,884 Thanks
  • 15,514 posts
Posted March 21, 2011 - 10:30 AM
Maybe you could use a steel colander from your wifes kitchen. They are round and bowl shaped, if you wanted to, you can reshape them.
#9 NUTNDUN OFFLINE
  • 10,351 Thanks
Posted March 21, 2011 - 10:32 AM
They say once you get to the 55 gallon drum size or larger line of sight isn't so much of an issue. What about a metal strainer, I understand it may not last too long so get cheap ones and do one assortment of nuts and bolts at a time?
I usually use all new hardware and don't worry about the original bolts or they get cleaned up for the most part from sandblasting and then I just wire brush anything that was missed.
#10 Bolens 1000 OFFLINE
  • 15,404 Thanks
  • 18,277 posts
Posted March 21, 2011 - 06:25 PM
:ditto:
I usually replace all nuts and bolts with new ones. except for an odd size
#11 NUTNDUN OFFLINE
  • 10,351 Thanks
Posted March 21, 2011 - 06:28 PM
The only thing that is bad about replacing nuts and bolts is with the Massey's the bolt heads have MF on them, so if you are trying to do a perfect restore you gotta keep some of them. I am not partial though to doing a perfect restore as I would rather have new hardware. Especially stainless hardware LOL.
#12 mikebramel OFFLINE
mikebramel
    Ron Paul
  • 177 Thanks
  • 1,009 posts
Posted March 21, 2011 - 06:31 PM
Not only that but alot of that chinese hardware is junk
#13 NUTNDUN OFFLINE
  • 10,351 Thanks
Posted March 21, 2011 - 06:34 PM
Why you buying chinese hardware? LOL j/k
#14 AV430 OFFLINE
AV430
  • 53 Thanks
  • 130 posts
Posted March 21, 2011 - 10:48 PM
That is cool that Massey put MF on their bolts, I never knew that. I guess just clean them up with a lot of elbow grease, after all they can be some real MF ers!:bigrofl::bigrofl: Adam
#15 Salatino OFFLINE
Salatino
  • 29 Thanks
  • 188 posts
Posted March 22, 2011 - 07:38 AM
I know what you mean as far as the bolts being samped. There stamped on the cubs also. If I cant find a ood replacement bolt off one of my parts tractors I'll grab a sainless one but so far I've been lucky.I didnt know they were stamped ntill I stated to clean the 5 or 6 coats a paint of them.!
