Kohler engine swap?
6 replies to this topic
#1 Cvans ONLINE
  • 7,144 Thanks
  • 6,312 posts
Posted April 24, 2015 - 08:35 PM
I have a K-301 12hp Kohler from a Wheel Horse that is in bad condition. It's has more power than what I need for what I'm doing. I've been offered a nice K-241 10hp. out of a JD 110. I know they were built on the same crankcase but is there any other changes that would prevent me from swapping these engines?
Thanks for your help.
  • 14,866 Thanks
  • 15,512 posts
Posted April 24, 2015 - 08:56 PM
Chris, the blocks aren't the same on the bottom I don't believe, Check out this thread.
http://gardentractor... series blocks
  • Cvans said thank you
#3 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted April 24, 2015 - 10:48 PM
I bought a JD210 for the engine and realized I couldn't use it on my tractor because there are engine mounting tabs cast onto the sides of the block itself.
Edited by wvbuzzmaster, April 24, 2015 - 10:48 PM.
#4 Cvans ONLINE
  • 7,144 Thanks
  • 6,312 posts
Posted April 24, 2015 - 11:44 PM
Man oh man what a mess. I guess I will just have to figure it out when I get the engine. Had no idea there were so many different versions of the same block. If nothing else I will just fabricate a different mounting plate. :wallbanging:    Used the 12hp. Kohler as a pattern figuring when I find a good engine they will interchange.
Almost scared to ask the next question, do all the engines mount with 4 bolts like mine? Please tell me yes!
#5 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted April 24, 2015 - 11:49 PM
No. Sorry. I think you can swap some oil pans around though, but the connecting rod dipper will need to be cut. I think you could make it work, but it may not look right ever.
#6 Cvans ONLINE
  • 7,144 Thanks
  • 6,312 posts
Posted April 24, 2015 - 11:56 PM
 After doing a little research it looks like the JD 110 was 8hp and he said his was a k241 10hp. so it must have come out of a JD210. I think I better get my ducks in a row tomorrow.
Thanks guys!!!!!
I'll be back for the rest of the story.
#7 KC9KAS OFFLINE
KC9KAS
  • 5,445 Thanks
  • 4,712 posts
Posted April 25, 2015 - 08:53 AM
Another question you may consider....Are both engines made with the bearing plate PTO end?
