homelte T-10 attachments
simplicity allis chambers
6 replies to this topic
#1 case1man OFFLINE
case1man
  • 189 Thanks
  • 135 posts
Posted April 24, 2015 - 05:28 PM
Have a homelite t-10 and a allis b-10 will any of the attachments interchange or the rear hitch off the allis fit the homelite
#2 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted April 24, 2015 - 05:31 PM
Hamman would know for sure, hopefully he will see this thread.
  • case1man said thank you
#3 skunkhome OFFLINE
skunkhome
  • 323 Thanks
  • 455 posts
Posted April 24, 2015 - 07:05 PM
Which T10 do you have? AC or Simplicity built? If you don't know post photo and we can tell you.
When you say "hitch" are you talking about the lift lever?
Edited by skunkhome, April 24, 2015 - 07:07 PM.
#4 case1man OFFLINE
case1man
  • 189 Thanks
  • 135 posts
Posted April 24, 2015 - 08:05 PM
Simplicity built same as 3410. Talking about the rear lift
#5 skunkhome OFFLINE
skunkhome
  • 323 Thanks
  • 455 posts
Posted April 24, 2015 - 09:36 PM
The B10 stuff should work on a Simplicity built T10. The lift lever will physically fit but you need a special bushing set for the left hand pivot. Some people use use the standard lock rings with a smaller diameter (OD) washer(s) in the middle. B10 used a rod running from the rock shaft to lift lever. 3410 uses a cable.
Edited by skunkhome, April 24, 2015 - 11:08 PM.
  • hamman said thank you
#6 hamman ONLINE
hamman
    Homelite Owner Extraordinaire
  • 6,436 Thanks
  • 2,860 posts
Posted April 24, 2015 - 10:25 PM
Some of the Homelite rear lifts were rectangle . If the rear lift is round as is the Allis B-10 they should fit. Now some were bigger than others. You would have to check and see if they will fit.        Roger
#7 skunkhome OFFLINE
skunkhome
  • 323 Thanks
  • 455 posts
Posted April 24, 2015 - 11:05 PM
This is a FDT lift lever on my 3414s.
