Gt 19.9
8 replies to this topic
#1 smithstractor OFFLINE
smithstractor
  • 2 Thanks
  • 3 posts
Posted April 24, 2015 - 05:00 PM
I have been having trouble with my sears. i have diagnosed it to be the Solenoid but for the life of me i cant figure out where it is to replace it. Any help would be gladly appreciated.
#2 Hobal OFFLINE
Hobal
  • 19 Thanks
  • 41 posts
Posted April 24, 2015 - 09:19 PM
do you mean the starter solenoid? and physically where it is on your sears? a few more details my friend please.
#3 MH81 OFFLINE
Posted April 25, 2015 - 06:22 AM
I believe it's up near the battery. Can look tonite.
How did you diagnose the solenoid?
#4 smithstractor OFFLINE
smithstractor
  • 2 Thanks
  • 3 posts
Posted April 25, 2015 - 06:34 AM
Yes the starter solenoid. i read the rest of the wires/circuits out and verified them for continuity/power. the only circuit that did not read properly was the circuit with the solenoid. after that i verified the safety switches to be good for continuity.
#5 MH81 OFFLINE
Posted April 25, 2015 - 06:37 AM
I will be near my 19.9 tonight, can tell you where it is then
  • smithstractor said thank you
#6 MH81 OFFLINE
Posted April 26, 2015 - 05:13 AM
Sorry, got home late.
The solenoid on my 19.9 is under the battery tray, mounted to the frame. Nar as I can see, It is inaccessible without removing the dash. You may be able to loosen the dash and move it to the side, but with 40 yr old plastic... You may be better off biting the bullet, remove the steering wheel, disconnecting everything and carefully removing the dash.
I was only able to verify location because my dash has a missing piece there and I could look in.
#7 KennyP ONLINE
  • 38,303 Thanks
  • 45,899 posts
Posted April 26, 2015 - 06:43 AM
Any way to come in from underneath?
#8 smithstractor OFFLINE
smithstractor
  • 2 Thanks
  • 3 posts
Posted April 26, 2015 - 08:03 AM
i was able to find it yesterday to replace it. I was able to replace it by removing the battery tray.
#9 MH81 OFFLINE
Posted April 26, 2015 - 11:28 AM
Ah, coming in from above... Never thought of that, since I could see it the the hole, I kinda got tunnel vision
