finally got spark ...then BANG ...BANG
64 replies to this topic
#1 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted April 23, 2015 - 08:15 PM
allis B112, cleaned the  brand new points after setting the gap at .18 . finally got a spark . put some gas to it and all I got was a loud BANG :wallbanging:  followed by another :wallbanging:  . I have been studying about points and spark and remember someone saying this same thing happened to them . decided to remove carb and clean it ( just cuz its gross ) any help would be greatly appreciated !!!!!
#2 adamjd200 OFFLINE
adamjd200
  • 2,045 Thanks
  • 2,173 posts
Posted April 23, 2015 - 08:17 PM
Is your spark plug still in place?
  • alec said thank you
#3 MH81 OFFLINE
Posted April 23, 2015 - 08:20 PM
Sounds like valve or timing. Are you sure the gap is right? How about the speed it's turning over?
#4 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted April 23, 2015 - 08:28 PM
spark plug is in . :bigrofl: I should double check that !!( just dawned on me what you meant . thought it was a stange question at first ... )
tried real hard to gap it right . it turns over faster than my B221 .
Edited by alec, April 23, 2015 - 08:32 PM.
#5 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted April 23, 2015 - 08:32 PM
The old cast iron Briggs do that sometimes when the carb is not right. If it continues with the carb rebuilt then It could be the timing advance.
#6 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted April 23, 2015 - 08:34 PM
the bottom of the carb filled with gas . this not normal right ?
#7 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted April 23, 2015 - 08:35 PM
You mean the mouth of the carb ?
#8 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted April 23, 2015 - 08:39 PM
that may be the case . Im learning . at least I finally know what a footdragger is hahaha only took a year + hahaha
#9 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted April 23, 2015 - 08:44 PM
Here are two pictures of carbs, which one is closet to the one you have ?
  • Sawdust and alec have said thanks
#10 tater195 ONLINE
tater195
  • 2,192 Thanks
  • 1,410 posts
Posted April 23, 2015 - 08:45 PM
If it turn over fast, you probably have a valve issue
#11 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
the one on the left .
#12 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted April 23, 2015 - 08:47 PM
whats the best way to check the valves ?
#13 tater195 ONLINE
tater195
  • 2,192 Thanks
  • 1,410 posts
Posted April 23, 2015 - 08:49 PM
Compression tester to verify, then pull the head and look at the valves
#14 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted April 23, 2015 - 08:51 PM
Ok, I wanted to make sure, people switch then out sometimes creating more problems.
On to the valves. Pull the head, careful not to tare or damage the head gasket. Using your hand turn the engine over until one of the valves is fully closed, you can spin the engine until both valves are fully closed for this test. Put your thumb on it and try twisting it, if either valves twist then it need to be lapped back into the seat.
#15 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
All yours then Taters. I am going to bed.
Edited by trowel, April 23, 2015 - 08:54 PM.
