Bolens 800 - High Rev Misfire Issues
#16
OFFLINE
Posted April 23, 2015 - 05:40 PM
- larisaPn said thank you
#17
OFFLINE
Posted April 23, 2015 - 05:45 PM
I am uploading a video to google so you can hear it running if that helps, Looking at your website there DrBolens.. now this is dangerous :)
#18
OFFLINE
Nope just gravity feed
- propane1 said thank you
#19
ONLINE
Posted April 23, 2015 - 05:46 PM
These did not have fuel pumps, have you tried taking out your fuel valve there is a fine screen that may be plugged, you should be getting fuel as full as the line is, if your only getting a small stream thats a problem.
I sent you a private message through the site
#20
OFFLINE
Posted April 23, 2015 - 05:47 PM
Wow wish I had found your website earlier..been getting ripped bit at Sams - 58$ for a float..couldn't find one anywhere at the time, Great website
- Bolens 1000 and propane1 have said thanks
#21
OFFLINE
Posted April 23, 2015 - 05:57 PM
I am going to buy a new tap from you today DrBolens - mine has no screen and doesn't actually work - I have a inline tap fitted further down the line. Had a inline filter to but that hindered the fuel flow to much and I suspect the tap is doing the same
#22
OFFLINE
Posted April 23, 2015 - 06:00 PM
#23
ONLINE
Yes, sam is generally about $15 to $ 20 above list price on most parts
#24
OFFLINE
Posted April 23, 2015 - 06:28 PM
Alright here are some videos of it going - you will here the miss when the exhast is facing, especially on that last video. Hopefully that gives the experts here more of a clue. https://drive.google...UE1NMGZBaEs5dkU
#25
OFFLINE
Posted April 23, 2015 - 06:58 PM
A high speed miss on a good carb is usually ignition related. If it was a points/ condenser set up I would suspect the condenser, bad connections on the plug wire or gap on the mag... BUT.... you seem to be having fuel supply issues as well. If it can idle forever but not handle FSNL instantly, I would go back to the ignition part
Edited by tater195, April 23, 2015 - 06:59 PM.
#26
ONLINE
Posted April 23, 2015 - 09:42 PM
A few thoughts:
The fact that you need to pour fuel down the intake to start the engine, points to fuel or compression problems. .....A vacuum leak or weak compression (due to valves not sealing properly, bad head gasket, worn piston rings, or scored cylinder bore) will cause difficult starting, as well as something simple such as the choke not closing completely.
These Wisconsin engines are very sensitive to ignition timing. ....You mentioned that the points are gapped properly. ...Did you use a feeler gauge, or did you set them as recommended by Wisconsin, using a continuity light or tester?
Welcome to GTT !
#27
OFFLINE
Posted April 24, 2015 - 06:12 AM
Interestingly it started well with just choke today, it has good compression, blasts my thumb off the hole when cranked. Don't have a tester so set the points by feeler gauge
#28
OFFLINE
Posted April 27, 2015 - 02:36 AM
Hi folks update here. Took the 800 for a good run today - around a hour of non stop run time. It ran quite well but on occasion and totally randomly would not rev up to full tilt or would rev itself down. The misfire seemed much less frequent as the running time grew longer. I feel it to be a carb issue but am not sure what would solve it. Different theories welcomed of course. It did for the most part run quite good just doesn't always want to rev right up or hold those revs. At full throttle for instance it might just cruise along and all of a sudden rev up to where it should be based on the throttle.
#29
OFFLINE
Posted April 27, 2015 - 05:30 AM
Could running rich cause these symptoms? - removing plug today reveals it to be quite black and sooty which is shows a rich mixture
#30
ONLINE
Posted April 27, 2015 - 08:26 AM
Black plug indicates a rich mixture or sometimes can be poor ignition.
Have you checked to make sure the governor lever on the engine is tight and adjusted right?
