Sand Blasting Powder Coating ?
16 replies to this topic
#1 Texas Deere and Horse ONLINE
  • 14,730 Thanks
  • 15,470 posts
Posted April 23, 2015 - 03:50 PM
Just wanting to see if anyone has sand blasted any power coated sheet metal like the heavy powder coat on JD stuff?
#2 mrmr56 OFFLINE
mrmr56
  • 202 Thanks
  • 122 posts
Posted April 23, 2015 - 04:16 PM
I did once. It will come off if the blast media is fresh and sharp. If it has been used a while, get ready for a long drawn out session with the blast cabinet.
  • NUTNDUN, Texas Deere and Horse and boyscout862 have said thanks
#3 JBRamsey ONLINE
JBRamsey
  • 1,412 Thanks
  • 813 posts
Removing powder coat is tough to do. You need a strong high volume compressor, a good blaster and aggressive media.
#4 petrj6 OFFLINE
petrj6
  • 4,083 Thanks
  • 2,369 posts
Posted April 23, 2015 - 06:38 PM
  watch out for that on sheet metal, the blaster can warp the metal if you blast on it for to hard or to long.
        Pete
  • Texas Deere and Horse, superaben and holdenboy1960 have said thanks
#5 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted April 23, 2015 - 08:21 PM
Brian, I tried to do it once and decided it was well worth sending to my local sandblasting shop.
Ben W.
#6 Jazz ONLINE
Jazz
  • 2,308 Thanks
  • 1,407 posts
Posted April 23, 2015 - 10:04 PM
Try 3M sandblasting discs. I use them on vintage autos for large areas so only the hard to reach places need to be sandblasted. 36grit sanding discs is another alternative to remove heavy coatings of paint and/or rust
  • MH81 and Texas Deere and Horse have said thanks
#7 petrj6 OFFLINE
petrj6
  • 4,083 Thanks
  • 2,369 posts
Posted April 24, 2015 - 04:43 AM
   If the powder coating is in good shape why remove it ?  if it is not all rusted to death or really in bad cond just sand it down a bit and paint over it. powder coat makes a great base for any paint and is easily sanded really smooth.
        Pete
  • Texas Deere and Horse, holdenboy1960 and MyTractorsSexy have said thanks
#8 Texas Deere and Horse ONLINE
  • 14,730 Thanks
  • 15,470 posts
Posted April 24, 2015 - 06:05 AM
        Pete
Pete, it is rusted really bad where the PC has come off, so it will be a job.
        Pete
that's what I'm worried about.
Ben W.
This is my thoughts also, ley the Pros take care of it.
  • superaben said thank you
#9 WHdbJD OFFLINE
WHdbJD
  • 671 Thanks
  • 510 posts
Posted April 24, 2015 - 06:39 AM
The only parts I blasted down to bare metal on my JD 318 were the panels
and battery tray that were corroded by the battery acid.
The rest of tractor was lightly blasted to "rough" them up a bit,
then two coats of primer over the powder coat. Then 4 coats of
green allowed to cure and wet sand by hand between each coat, with
800, 1000, and 1500 grit.
  • Texas Deere and Horse, KennyP and holdenboy1960 have said thanks
#10 Texas Deere and Horse ONLINE
  • 14,730 Thanks
  • 15,470 posts
Posted April 24, 2015 - 09:51 PM
My problem is that part of the fender pan is pealed and badly rusted and part of it is still good powder coated.
#11 shorty ONLINE
shorty
  • 5,290 Thanks
  • 5,170 posts
Posted April 25, 2015 - 06:59 AM
That is what I have found with powder coated peices. There is no sign of trouble until a bigger section peels off. Rust can travel behind the paint without being obvious. With spray paint, it usually bubbles where it starts.
#12 Texas Deere and Horse ONLINE
  • 14,730 Thanks
  • 15,470 posts
Posted April 25, 2015 - 07:11 AM
Will Electrolysis take off powder coating?
#13 Texas Deere and Horse ONLINE
  • 14,730 Thanks
  • 15,470 posts
Posted April 27, 2015 - 07:18 PM
BUMP !!
#14 Talntedmrgreen ONLINE
  • 3,234 Thanks
  • 2,302 posts
Posted April 30, 2015 - 01:28 PM
I don't' believe so....if I understand electrolysis correctly, it decomposes rust, not necessarily paint or other applied finishes.
I recently tried my and at this, on some small brackets for a mower redo.  The rust was long gone after several hours bubbling away, but the painted areas remained...painted.  If there is loss of adhesion and rust behind your powder coat, then it should fall away as the rust is removed, but would have done that without electrolysis.
  • WHdbJD said thank you
#15 Cvans ONLINE
  • 6,468 Thanks
  • 6,059 posts
Posted April 30, 2015 - 10:50 PM
I am NOT a fan of powder coating. Once you get a chip in it I'd swear that it promotes rust.
I hope you get  this figured out Brian as the stuff is nasty to work with.
