Ford 09SA1448 Direct Drive Rotary Mower Deck
ford ford lgt ford lgt14d 09sa1448 ford 48 inch deck ford deck gearbox
3 replies to this topic
#1 kyle9859 OFFLINE
kyle9859
  • 1 posts
Posted April 23, 2015 - 02:48 AM
I was given a Ford LGT14D.  The tractor itself is in great shape, but the deck needs work.  I am in the process of replacing the bearings, but I cannot find any scematics, or service manuals over the Deck itself.  My problem is with the gearbox, as it is apart and in pieces in a box from a repair shop (not my doing).  All the pieces are there except one snap ring.  My question is, can anyone tell me how to get the Gearbox and Spindles back together?  I can get them on and off the deck shell, no problem, but rebuilding the spindles and gearbox are becoming problematic, and there is little to no literature.  I have obtained the Operators manual for the LGT14D deck (Ford 48" 09SA1448) but it is merely a operators manual.
I hope someone know anything about the LGT14 Direct drive mowers!
#2 KennyP OFFLINE
  • 40,881 Thanks
  • 47,091 posts
Posted April 23, 2015 - 04:25 AM
New Holland has a listing for that deck. Here a screenshot of it.
  • tinbender7 and boyscout862 have said thanks
#3 boyscout862 ONLINE
  • 13,549 Thanks
  • 9,427 posts
Posted April 23, 2015 - 05:47 AM
Welcome to GTT. Congratulations on having a great tractor. Good Luck, Rick
  • tinbender7 said thank you
#4 Miner OFFLINE
Miner
  • 1 Thanks
  • 4 posts
Posted July 03, 2015 - 03:07 PM
I have the same deck and gearbox partially disassembled right now.  I cannot remove the #8 gear.  I have the cir-clip removed and the input shaft and bearings removed.  There isn't enough clearance for a typical gear puller.  Any ideas?
To the OP.  Reassemble from the bottom up, and ensure the output seal is properly seated. Note there should be a thin spacer between #31 and the case, these are loaded from the inside before inserting the input shaft.
Edited by Miner, July 03, 2015 - 03:08 PM.
Also tagged with one or more of these keywords: ford, ford lgt, ford lgt14d, 09sa1448, ford 48 inch deck, ford deck gearbox
