Hydro oil change?
21 replies to this topic
#16 KennyP ONLINE
  • 40,954 Thanks
  • 47,136 posts
Posted April 27, 2015 - 09:44 AM
Those are a lot cheaper and easier to find. The Wix # is 51307
  • breimer said thank you
#17 TUDOR OFFLINE
TUDOR
  • 565 Thanks
  • 507 posts
Posted April 29, 2015 - 12:04 AM
Sundstrand and Eaton are quite flexible for the type of fluid that is put in their hydros. Quality hydraulic oil, motor oil, and ATF are all acceptable.
JD recommends their HyGuard (house brand), MF recommends M-1110 (house brand) or ATF Type A (now Dexron), and other tractor manufacturers spec their own house brands, motor oils of various viscosities, or ATF Type F, all for the same transmissions.
I've been happy with the Dexron that is in my MF1655 since 1982, but it has spent most of its hours moving snow in temperatures as low as -30°. It has gotten to work in the summer heat (+90°) as well.
Edited by TUDOR, April 29, 2015 - 12:05 AM.
#18 kkmac OFFLINE
kkmac
  • 2 Thanks
  • 8 posts
Posted April 29, 2015 - 08:06 AM
hi, where did you pick up your filter? I have a 1979 LGT 165.
Kevin
Mine is inline
#19 kkmac OFFLINE
kkmac
  • 2 Thanks
  • 8 posts
Posted April 29, 2015 - 08:08 AM
I'm looking for an inline filter for my 1979 LGT 165
#20 KennyP ONLINE
  • 40,954 Thanks
  • 47,136 posts
Posted April 29, 2015 - 08:52 AM
New Holland has them! Grab your wallet! Part # 87346701 and it's >$117. I'm changing mine to a screw-on next time around!
#21 aevansgatech OFFLINE
aevansgatech
  • 213 Thanks
  • 261 posts
Posted April 29, 2015 - 09:59 AM
Just checked my ford YT16H manual and it says you shouldn't have to change trans oil, but I'd like to anyway
Calls for detergent SAE20.. Sound right?
#22 breimer OFFLINE
breimer
  • 134 Thanks
  • 167 posts
Posted May 04, 2015 - 07:21 AM
Thanks all for your replies. I'm enjoying this forum as many people post info.I have found that I can run John deere Hygard and John Deere filters and I do so because I work for a Deere dealer and can get these at a discount. But it's good to know all these options. Thanks again.
