MF 10 magneto
for free
9 replies to this topic
#1 ryanw OFFLINE
ryanw
  • 6 Thanks
  • 10 posts
Posted April 22, 2015 - 08:06 AM
I am in need of a starting magneto for the Tecumseh 10 hp engine. I bolts right on the side of the block sort of behind the flywheel. They are discontinued through Tecumseh and I can't seem to find one anywhere. Does anyone know where to look for this part?
#2 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,172 Thanks
  • 5,770 posts
Posted April 22, 2015 - 08:27 AM
Try the vendors on this site.
#3 TAHOE ONLINE
TAHOE
  • 6,936 Thanks
  • 5,194 posts
Posted April 22, 2015 - 09:05 AM
Is it a magneto or an SSI module?
#4 ckjakline OFFLINE
ckjakline
  • 1,120 Thanks
  • 1,114 posts
Posted April 22, 2015 - 03:01 PM
If you do find one they bring big money.There is a chrysler ignition set up on engines and magnets .com. If your engine has point it would be easier to put on a 12v coil and switch it to battery ignition.
#5 ryanw OFFLINE
ryanw
  • 6 Thanks
  • 10 posts
Posted April 22, 2015 - 03:27 PM
I guess you would call it an SSI module or "solid state ignition". I do have battery ignition already I think all this item does is deliver spark while the engine is running.
#6 MH81 OFFLINE
  • 28,446 Thanks
  • 29,126 posts
Posted April 22, 2015 - 04:13 PM
A picture of what you have will answer a lot of questions and end supposition.
Take a picture of the module/SSI/mag that you need and maybe a couple of others and then one of our site sponsors can help or there are other options as well.
#7 glgrumpy OFFLINE
  • 7,226 Thanks
  • 6,935 posts
Posted April 22, 2015 - 06:27 PM
I can't find the bag I had with tech parts place address on it, but what is left of them is in Janesville, WI.  If was on later engines, would think they might have it in stock. Anyone have that address here?  OR, epay and swapmeets, checking for dealers with old stock and such things.  Check dealers on here, they are always buying up old stock from closing dealers. You sure that isn't one of those computers for the safety switches and controls that many newer rigs have now?  If they go bad, whole tractor is dead and won't run. Might check with the brand dealer and see what they say it is.  Doesn't seem right that magneto would be on outside of the engine is why I'm saying this.
#8 TAHOE ONLINE
TAHOE
  • 6,936 Thanks
  • 5,194 posts
Posted April 22, 2015 - 09:00 PM
If it's battery, then we really need to see a pic to help ya determine what you need. There are so many modded ignitions out there now.
#9 ckjakline OFFLINE
ckjakline
  • 1,120 Thanks
  • 1,114 posts
Posted April 23, 2015 - 08:11 PM
If it's a SSi module it's not going to be battery ignition. If the SSi module gets power its going to get fried. Battery ignition is an automotive type coil
#10 ryanw OFFLINE
ryanw
  • 6 Thanks
  • 10 posts
Posted April 25, 2015 - 07:24 AM
Here is a picture of the part I am looking for. It is item 81 in the picture.
Also tagged with one or more of these keywords: for free
