john deere 265 will not start
fc540v kawasaki backfires
5 replies to this topic
#1 gtLeakey OFFLINE
gtLeakey
  • 1 Thanks
  • 2 posts
Posted April 21, 2015 - 08:30 PM
I have a John Deere 265 with a Kawasaki FC540V - DS00 engine.  After sitting all winter it was very hard to get started.  Kept backfiring.  Put in a new spark plug and finally got her started.  Mowed for about an hour shut it off and called it a day.  Next day same thing only backfired and would not start.  Checked the valve clearance and it was off.  Adjusted to .006 both exhaust and intake.  It started up  with just a couple of revolutions.  Great I thought. Shut it off and restarted several times.  Then shut it off and changed oil and all the filters.  Tried to restart and again only backfiring.  Rechecked valve clearance and it is still in spec.  Took flywheel off and check the key and key way.  Both OK.  Tried to start again and just real bad backfiring,  Does anyone have any ideas?.  I am thinking of taking head off and checking valves!
#2 HDWildBill OFFLINE
  • 8,975 Thanks
Posted April 21, 2015 - 09:05 PM
Welcome to GTT. I know the FD 590 has an electronic ignition control located on the left rear of the ending.  Yours may have the same.
  • gtLeakey said thank you
#3 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,750 Thanks
  • 4,244 posts
Posted April 22, 2015 - 01:17 AM
welcome to GTT. have you also controlled the gasoline? if you need a manual for the Kawa, you'll find it here
Edited by jd.rasentrac, April 22, 2015 - 02:33 AM.
#4 propane1 OFFLINE
propane1
  • 8,467 Thanks
  • 4,037 posts
Posted April 22, 2015 - 05:38 AM
Bad fuel. Wrong spark plug. Dirty carb. Sounds like a fuel problem to me. Just some ideas, Noel.
#5 JDBrian OFFLINE
  • 9,610 Thanks
  • 14,144 posts
Posted April 22, 2015 - 07:05 AM
You might also want to have a look at your wiring harness and check for loose wires, bad connections etc. That includes the chassis connections back to the battery - terminal.
#6 gtLeakey OFFLINE
gtLeakey
  • 1 Thanks
  • 2 posts
Posted April 23, 2015 - 12:15 PM
Thanks for the information on the Kawasaki engine.  When I first started the engine I put seafoam in the fuel tank and ran it for a hour or so until the tank became empty.Then I put in fresh fuel and it started right up.  I then ran it for another hour before shutting it off.  As many of you suggest a fuel problem I will take the carb. off clean and rebuild with new kit.  Wish me luck !
  • propane1 said thank you
