Front Bumper + Weight
3 replies to this topic
#1 KennyP ONLINE
  • 37,469 Thanks
  • 45,490 posts
Posted April 21, 2015 - 05:25 PM
Here's another bright idea from me! As you folks know by now, I like my FF's. But, the first time I plowed with one, I had issues with it wanting to wheel stand in hard dirt. So I built a basket on the front with 70 lbs of cast iron window weights in there.
That was 2 years ago. Now, I am tired of hearing the weights rattling around up there. But I want a bumper to help protect the fiberglass hood on this tractor. Aaron had a tubing bender (ala HF) out back and I had access to some 2"OD X 0.1" wall tubing. So I proceeded to make a bumper system for this tractor. I still wanted the extra weight up front. Then it hit me that I have all this lead. Filling the bumper with the lead would solve both issues.  So I began the task of making this. Here's pics of what I have thus far.
I bent the pipe, one long that will go low, one short above it.
I needed to cap the ends to keep the lead in when I pour it, so I made some caps out of 1/8" metal.
The one on the left is a 5/8" thick plug I cut using this same method.
The 2 caps welded on one end of the tubes.
One pipe folded some upon bending, so I added in some filler material to fix that.
To be continued!
  • Bud, Gtractor, hamman and 5 others have said thanks
#2 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted April 21, 2015 - 10:52 PM
  Kenny, you're probably old enough to already know, but I'll say it anyway. Get the pipe real hot before pouring in the lead for two reasons. #1- to ensure the lead goes all the way to the other end before solidifying. #2- and most important, to ensure there is no moisture inside the pipe.
                                          Mike
  • IamSherwood, KennyP and alec have said thanks
#3 glgrumpy ONLINE
  • 8,560 Thanks
  • 7,881 posts
Posted April 22, 2015 - 03:17 AM
SO, your making a Pipe Bomb bumper to go out and find a JD to run into?  THAT'S the real story here!
  • limebuzz, KennyP, Cat385B and 1 other said thanks
#4 greenb69 OFFLINE
greenb69
  • 270 Thanks
  • 210 posts
Posted April 22, 2015 - 04:50 AM
Great idea on the bumper. I have some 4 inch pipe I am not using but won't fill it with lead. Do have a neighbor with a jd though. LOL.
  • KennyP and alec have said thanks
