Plow Storage
4 replies to this topic
#1 KennyP ONLINE
  • 40,146 Thanks
  • 46,773 posts
Posted April 21, 2015 - 12:16 PM
Both the plows I just repainted have depth wheels on them and that causes an issue when they aren't on the tractor. They are quite 'tippy', wanting to fall over at the slightest movement. This can be an issue, especially if they are at a show. Someone could get hurt if a plow fell on them. So I studied the problem and came up with this solution.
The first pic shows the blocks I have now under the depth wheels to keep them up.
I had some thin strap that I bent to hang of the top of the share. I drilled a hole through these to bolt to some extra chunks of lead I have.
Here they are hanging on the shares.
Notice the wood blocks are removed from under the depth wheels. They are both very steady and it would take a lot to make them fall over now.
  • MH81, trowel, tinbender7 and 3 others have said thanks
#2 Coventry Plumber OFFLINE
Coventry Plumber
  • 1,089 Thanks
  • 590 posts
Posted April 21, 2015 - 03:44 PM
Great idea!
#3 MH81 OFFLINE
Posted April 21, 2015 - 04:15 PM
I have tipped them over at shows before, better than it falling on someone's foot.
Nice ballast technique. Thanks.
#4 KennyP ONLINE
  • 40,146 Thanks
  • 46,773 posts
Posted April 21, 2015 - 04:46 PM
You almost need to crawl on them before they will tip now. I know most folks don't have access to the lead, but something else can be used if placed right.
  • trowel said thank you
#5 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted April 21, 2015 - 04:59 PM
Barbell weights.
