SS15 Question
6 replies to this topic
#1 bbuckler OFFLINE
bbuckler
  • 3,752 Thanks
  • 3,262 posts
Posted April 20, 2015 - 09:08 PM
I can't find the model number on the motor. anybody know the model number ? I need to order a carb kit.
  • Sawdust said thank you
#2 Sawdust OFFLINE
Sawdust
  • 6,152 Thanks
  • 3,547 posts
Posted April 20, 2015 - 09:52 PM
Your numbers are on the side of the shroud. Mine are
Model 325431
Type 0139-01
Code 7206291
Carb kit 121 Double check with Ben in our vendors section under Old Paths Equipment he should have them.
Edited by Sawdust, April 20, 2015 - 10:09 PM.
  • boyscout862 and bbuckler have said thanks
#3 bbuckler OFFLINE
bbuckler
  • 3,752 Thanks
  • 3,262 posts
Posted April 20, 2015 - 10:11 PM
Model 325431
Type 0139-01
Code 7206291
You think this will work http://www.ebay.com/...=item4636ec38bb
#4 Sawdust OFFLINE
Sawdust
  • 6,152 Thanks
  • 3,547 posts
Posted April 20, 2015 - 10:45 PM
In their finer print it lists that it will fit but I looked at their return policy & it sounds kind of sketchy a 15% restocking fee for eligible returns. If they consider it not eligible for some reason your stuck with it. Be careful with some after market parts. The seller also has 100 negitives in the last 12 months  :(
Edited by Sawdust, April 20, 2015 - 10:49 PM.
  • boyscout862 and propane1 have said thanks
#5 Bolens 1000 ONLINE
  • 15,396 Thanks
  • 18,275 posts
Posted April 21, 2015 - 06:42 AM
Ben may have these kits in stock if you check with him
I can also get them as well for $26.50 shipped
  • bbuckler and Jazz have said thanks
#6 bbuckler OFFLINE
bbuckler
  • 3,752 Thanks
  • 3,262 posts
Posted April 21, 2015 - 05:45 PM
ImageUploadedByTapatalk1429656246.438384.jpg is this piece in the kit ? It the piece where the needle on the bowl screws in
#7 Bolens 1000 ONLINE
  • 15,396 Thanks
  • 18,275 posts
Posted April 21, 2015 - 06:44 PM
Yes I believe it comes with the top portion
Here's a pic of the kits contents
$%28KGrHqR,%21m%21E1F3RliZbBN%28Y,66pMQ~
  • Sawdust and bbuckler have said thanks
