in need of a drive shaft
25 replies to this topic
#1 Gary400 OFFLINE
Gary400
    JD,junkie
  • 225 Thanks
  • 768 posts
Posted March 19, 2011 - 10:30 PM
i cant figure out how to post in the classifieds so i'll ask here i guess . i need a drive shaft for a 317 its a 1979 if it makes a difference in years . thanks :anyone:
#2 jdslednut ONLINE
jdslednut
  • 678 Thanks
  • 851 posts
Posted March 20, 2011 - 12:43 AM
I know it will make a difference as to which engine you have in it. You'd maybe want to post that info. Good luck!
#3 Gary400 OFFLINE
Gary400
    JD,junkie
  • 225 Thanks
  • 768 posts
Posted March 20, 2011 - 08:45 AM
tractor is a JD C317L 199574 M - engine is a KT17QS , spec# 24301 . so what i can find is it is a 1982 not a 1983 like i was told . i also have a 1979 317 and i have the drive shaft out of it but both universal joints are out of it . both drive shafts appear to be the same but this has got me scratchin my head . the engine with the spec.# 24301 is a series II and it came off of the 1979 tractor which leads me to believe that the 79 was re-powered with the updated engine that i now have on the 82 . are ya confused now
:wallbanging:
#4 olcowhand ONLINE
  • 40,335 Thanks
  • 31,169 posts
Posted March 20, 2011 - 08:49 AM
If it's a newer series II KT17, they share the same flywheel as the series I, so any 317 driveshaft will fit. They only came with the KT engine. The driveshafts are a weak point, not having grease fittings & replaceable joints.
#5 MH81 OFFLINE
Posted March 20, 2011 - 08:54 AM
I wonder, has anyone figured out a way to replace the u-joints, or does someone make an aftermarket with grease fittings?
#6 olcowhand ONLINE
  • 40,335 Thanks
  • 31,169 posts
Posted March 20, 2011 - 09:00 AM
On my BIL meangreen's 317, we repowered with an Onan & I built him a driveshaft from an MF14 with large greasable joints. Had to machine an adapter to the Onan engine, as the MF shaft hooked to a Kohler crank, and on the other end adapted to the input shaft of the hydro. That shaft will likely never wear out the joints now.
#7 Gary400 OFFLINE
Gary400
    JD,junkie
  • 225 Thanks
  • 768 posts
Posted March 20, 2011 - 09:24 AM
thats what i may end up doing just build my own . im not giving JD $ 150.00 to $200.00 for a drive shaft that is just like the one in it now . i realize this shafts been in use for 29 years but i may want to use it another 29 .
#8 mikebramel OFFLINE
mikebramel
    Ron Paul
  • 177 Thanks
  • 1,009 posts
Posted March 20, 2011 - 11:51 AM
$150 doesnt seem to bad. Are you sure on that? You might have forgot its a Deere LOL
A little bit of work goes a long way
#9 Reverend Blair OFFLINE
Reverend Blair
  • 501 Thanks
  • 952 posts
Posted March 20, 2011 - 12:00 PM
Can't those u-joints be replaced? If you can get them out, you should be able to take them down to a bearing supply place (the place I go is actually called Bearing Supply) and they should be able to fix you up with something that fits and is greaseable.
#10 101 senior OFFLINE
101 senior
  • 239 Thanks
  • 372 posts
Posted March 20, 2011 - 03:38 PM
I had an adjustable length shaft built for an Ariens 14. It worked well. I still have it if your interested. Built out of square stock
#11 Gary400 OFFLINE
Gary400
    JD,junkie
  • 225 Thanks
  • 768 posts
Posted March 20, 2011 - 07:46 PM
thanks 101 , im going to make a few calls tomorrow but if i cant come up with something i may take you up on that offer
#12 ducky OFFLINE
  • 1,982 Thanks
  • 4,103 posts
Posted March 20, 2011 - 08:12 PM
Gary, I believe that the shaft OD is 3/4" and if you do not have enough shaft left after you cut the bad joints out just start with a new shaft and use #6 joints from TSC or other suppliers. Have had to build a lot for the MFs and Snappers. We can not get then OEM.
#13 AV430 OFFLINE
AV430
  • 53 Thanks
  • 130 posts
Posted March 20, 2011 - 09:43 PM
Gary, I just went through this with my 1981 317. I decided to go with the Replacement shaft from John Deere. $190.00 is what I paid and the new drive-shafts have zerc fittings at the u-joints. I doubt I will wear this one out! Adam
#14 olcowhand ONLINE
  • 40,335 Thanks
  • 31,169 posts
Posted March 21, 2011 - 08:34 AM
I believe I'd go Adam's route being the new one from JD has grease fittings. If you don't get the driveshaft correct, it'll shake things to death. Ask me how I know! LOL Sounds like JD learned something being they upgraded the replacement shafts.
Edited by olcowhand, March 21, 2011 - 08:41 AM.
#15 Tmo OFFLINE
Tmo
  • 360 Thanks
  • 486 posts
Posted March 21, 2011 - 02:12 PM
That serial number places it as a 1982.
Model:317 Typecode:C317L Serial Number:199574 Model Year:1982 Engine Model and Size:KT17QS Kohler 17HP Lift Type:Hydraulic 2 Lever Paint:Green Manufactured Location:Horicon, WI
