Wisconsin AEND Manual
55 replies to this topic
#31 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted April 20, 2015 - 03:50 PM
Because it is Mil spec, it will not be on the database. Inside the serial number there will be a number or two that will be different from the other AEND engines showing that change.
#32 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted April 20, 2015 - 03:53 PM
Continental Motor Corp's military division Teledyne would know the needed info on that engine, that is if they even retained it which I doubt considering they have nothing to do with any engine below 50 hp since the collapse of the Wisconsin Robin line.
It would be worth a try ??
#33 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted April 20, 2015 - 03:56 PM
I am thinking that engine spun a air compressor with the double groove clutch and wide base plate. What I find interesting it the external car coil bolted to the head ? wonder what happened with the old ''buzz box'' ?
Edited by trowel, April 20, 2015 - 03:57 PM.
#34 chivo909 OFFLINE
chivo909
  • 12 Thanks
  • 27 posts
Posted April 20, 2015 - 03:57 PM
#35 chivo909 OFFLINE
chivo909
  • 12 Thanks
  • 27 posts
Posted April 20, 2015 - 03:58 PM
That's the way I got it, and what's a buzz box?
#36 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted April 20, 2015 - 04:00 PM
Now that you mention the "D" prefix I want to say it  was Distributor equipped but cant say for certain
You were right. I am digging deep into my files but I am a bit confused as to why, I only have assumptions, you have a much larger and better Wisconsin data base, what do you make of this external coil add on ? I have wondered about that for a number of years now.
#37 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted April 20, 2015 - 04:04 PM
Can you show more pictures of the wire that runs into the carb, and the Dis. ? I have a idea,..
#38 chivo909 OFFLINE
chivo909
  • 12 Thanks
  • 27 posts
Posted April 20, 2015 - 04:08 PM
Sure, ill get more pictures when I get off work. I live in California and it is hard to find parts locally, I have to look back east.
#39 chivo909 OFFLINE
chivo909
  • 12 Thanks
  • 27 posts
Posted April 20, 2015 - 04:10 PM
Glad I joined! Y'all are great!
  • Bolens 1000 and olcowhand have said thanks
#40 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted April 20, 2015 - 04:15 PM
By the way, welcome to GT Talk.
Bolens1000, Brian is our Wisconsin, Bolens, Garden Way dealer and is a great person who truly enjoys this.
I enjoy the odd ball different stuff.
Edited by trowel, April 20, 2015 - 04:15 PM.
  • Bolens 1000 said thank you
#41 Bolens 1000 OFFLINE
  • 15,540 Thanks
  • 18,316 posts
Posted April 20, 2015 - 04:16 PM
I'll have to do some research on this, I dont think I've ever seen an ignition box like that before!
It seems like some stuff is not original but its hard to say, I have yet to get one of these series here in person to actually see the ins and outs of these models
#42 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted April 20, 2015 - 04:21 PM
Brian, I have an idea for your considerations. This being Mil-spec and having a Dist and external coil bolted to the head for the typical set up I wonder if the ''buzz box'' is for a carb warmer for sub temp start up instead of ignition. The aluminum box is similar to the mill-spec external boxes on the Mill-spec THF engines but the pictures are not 100 % clear and I am not 100 % sure. I have seen weirder set up from the 50's on Lauson engines also built for the military before the introductions of the MSE in 54.
#43 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted April 20, 2015 - 04:59 PM
Wisconsin mil-spec power genset manual.
#44 chivo909 OFFLINE
chivo909
  • 12 Thanks
  • 27 posts
Posted April 20, 2015 - 05:09 PM
ImageUploadedByTapatalk1429567733.912046.jpg ImageUploadedByTapatalk1429567747.272969.jpg ImageUploadedByTapatalk1429567763.643125.jpg ImageUploadedByTapatalk1429567777.436739.jpg ImageUploadedByTapatalk1429567788.088525.jpg
#45 chivo909 OFFLINE
chivo909
  • 12 Thanks
  • 27 posts
Posted April 20, 2015 - 05:26 PM
ImageUploadedByTapatalk1429568716.115856.jpg ImageUploadedByTapatalk1429568727.337310.jpg ImageUploadedByTapatalk1429568736.607682.jpg
This was my first project, saved if from a junker who was going to scrap it, everything works on it!!
  • trowel and boyscout862 have said thanks
