The struggle of buying new deck blades
13 replies to this topic
#1 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted April 20, 2015 - 08:50 AM
So im trying to buy new blades for my JD GT 275 with a 48" deck an either the books at stores dont go back far enough or i get a blank stare when i tell them what i have a need the blades for. Has anyone else had this problem when trying to buy new blades? An can anyone help me with a part number for blades or the length that i will need?
#2 Cat385B ONLINE
    HAZMAT CAT
  • 13,974 Thanks
  • 10,004 posts
Posted April 20, 2015 - 08:57 AM
Part # M115495
High lift blades M135589
Mulching B1PD1024
16 5/8" long, 2.5" wide, .197 thick, 51/64" arbor hole.
  • backwoods and boyscout862 have said thanks
#3 Bolens 1000 ONLINE
  • 14,987 Thanks
  • 18,140 posts
Posted April 20, 2015 - 09:02 AM
If that is the correct part number I can get you some nice USA made ones for $15.50ea
There's an option for a regular cut or mulching blade both the same price
  • trowel, backwoods and boyscout862 have said thanks
#4 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted April 20, 2015 - 09:11 AM
Thank you for the info im gonna try to buy them through work an see what the price is for all 3 of them
#5 Cat385B ONLINE
    HAZMAT CAT
  • 13,974 Thanks
  • 10,004 posts
Posted April 20, 2015 - 09:13 AM
Brian's quoted price is the same as the discount site I was referencing. JD will be 25% more, minimum.
Brian's service vs JD's? That's like comparing your local cafe vs McDonalds. Brian actually cares about service.
  • Bolens 1000, trowel and backwoods have said thanks
#6 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted April 20, 2015 - 09:15 AM
i can order them over night at work for a good price
Edited by backwoods, April 20, 2015 - 09:17 AM.
#7 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted April 20, 2015 - 09:16 AM
the blades at work are sme at napa
#8 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted April 20, 2015 - 09:17 AM
whats the difference between high lift an regular blades?
#9 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted April 20, 2015 - 09:23 AM
Correct on all counts and then some. Brian, I may switch to Bolens just because of you :rocker2:
High lift is for bagging and/or sucking up the grass so it can be cut. Some blades like Snapper has pre-drilled holes for ad-on ''wings'' for more lift. General rule is higher hp engine is needed for the bagging, engine works harder, similar to spinning a airplane propeller.
  • Bolens 1000 and backwoods have said thanks
#10 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted April 20, 2015 - 09:34 AM
ok so the normal blades will be fine for my weekly mowing then
#11 Cat385B ONLINE
    HAZMAT CAT
  • 13,974 Thanks
  • 10,004 posts
Posted April 20, 2015 - 09:37 AM
Yep.
  • backwoods said thank you
#12 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted April 20, 2015 - 09:45 AM
Ok since i dont bag the clippings or the leaves it makes more sense then to go this way thanks for the help guys with the part numbers
#13 aevansgatech OFFLINE
aevansgatech
  • 213 Thanks
  • 261 posts
Posted April 20, 2015 - 09:48 AM
Having trouble finding replacement blades for my 38" ford deck too.. NH 9849582
From what I measured, they're 19" long, but have a 3/8" mounting hole. All the newer blades either have a larger hole, or a star-shaped cutout.
#14 Bolens 1000 ONLINE
  • 14,987 Thanks
  • 18,140 posts
Posted April 21, 2015 - 04:11 PM
I can probably get something that will work, here's a 19'' with 3/8'' center hole
Are you measuring the blade as shown below to get 19''?
