Massey MF10 / MF12 Peerless transmission shifter parts.
47 replies to this topic
#46 rjl OFFLINE
rjl
  • 12 Thanks
  • 15 posts
Posted September 25, 2012 - 08:14 PM
Yes I have the correct gasket. It turns through all the gears correctly just hard to turn by hand with the drive pully. Before I could turn it with just the shaft.
#47 rjl OFFLINE
rjl
  • 12 Thanks
  • 15 posts
Posted September 26, 2012 - 08:18 PM
I got it all back together correctly. As soon as I pulled the right side back off I realeized what I did wrong. When I took the right side bushing out to replace the axle seal I had to drive it out from the back side. Easily done but in looking on how to do the same to the left side I pulled off a washer and temporarily set it on top another washer on another set of gears. I saw it and corrected it instantly then put everything back together with no issues.
Thanks again for the instructions and parts list.
#48 MH81 OFFLINE
  • 30054 Thanks
  • 29761 posts
Posted September 26, 2012 - 10:04 PM
Great news it was that simple. Glad you pulled it apart instead of taking the chance, those trannies are tough, but weird pressures can crack a case.
