Massey MF10 / MF12 Peerless transmission shifter parts.
47 replies to this topic
#31 NUTNDUN OFFLINE
  • 10446 Thanks
  • 15622 posts
Posted March 30, 2011 - 08:31 AM
I wanted to post an update now that it is all back together. It is extremely easy to find 2nd gear now and it stays in gear just fine. All gear positions now feel solid when you shift in to them. I found my first gear lockout piece but I need to fix the bolt hole in the sheet metal seat pan, looks like someone ripped the old one out. Will probably try and do that this weekend as I would like to have it on there for the plow day.
#32 DMF OFFLINE
DMF
  • 16 Thanks
  • 285 posts
Posted March 30, 2011 - 10:23 AM
Great thread George. I'm sure this info will come in handy during my rebuild!
#33 HowardsMF155 OFFLINE
  • 3079 Thanks
  • 3084 posts
Posted June 22, 2011 - 10:09 PM
I have a new-to-me MF12G that I am going to have to do some work to. One of the problems is that oil is leaking out near the axle shaft on the right hand side. It looks like there is an oil seal in the transmission case, is there any oil seal at the outboard end of the axle shaft near the hub? Or will I have to remove an axle extension peice to get at the transmission to replace the seal?
Thanks,
Howard
#34 NUTNDUN OFFLINE
  • 10446 Thanks
  • 15622 posts
Posted June 23, 2011 - 04:54 AM
Thanks,
Howard
It is only the seal at the case where the axle tube meets. John Deere sells the seals and gaskets for a good price too. If you do a search and find my thread about replacing the detent balls I have the part numbers listed in there.
#35 HowardsMF155 OFFLINE
  • 3079 Thanks
  • 3084 posts
Posted June 23, 2011 - 09:37 PM
Hi George,
This is the thread where you rebuilt your transmission. I think it should be a sticky. Lots of awesome information.
Howard
#36 greencoach47 OFFLINE
greencoach47
  • 8 Thanks
  • 85 posts
Posted June 23, 2011 - 11:59 PM
Thank you George for this great post as I recieved my parts for this job from Jacks in the mail today. I don't know that my trans needs the work but it was recomended that I do this before I reinstall the unit back on the tractor. I as well have never tackled a similar job so thanks again.
#37 NUTNDUN OFFLINE
  • 10446 Thanks
  • 15622 posts
Posted June 24, 2011 - 04:08 AM
Hi George,
Howard
Thanks Howard, I need to do a write up and make it an article under the how to section of the site. Time has not been my friend as of late though.
#38 NUTNDUN OFFLINE
  • 10446 Thanks
  • 15622 posts
That is all that matters to me is that it helps fellow members if they need it :D
  • reliabilt said thank you
#39 KennyP ONLINE
  • 51064 Thanks
  • 52665 posts
Posted June 24, 2011 - 05:07 AM
Guess I haven't snooped around enough. Where's the how to section, George?
#40 NUTNDUN OFFLINE
  • 10446 Thanks
  • 15622 posts
Posted June 24, 2011 - 05:23 AM
Garden Tractor Talk - How-Tos
You can also get to it by going to the home page and on the right hand side is a section menu.
  • KennyP and HowardsMF155 have said thanks
#41 KennyP ONLINE
  • 51064 Thanks
  • 52665 posts
Posted June 24, 2011 - 05:45 AM
Okay, I found it once before. Need to snoop around in there some more. Thanks.
#42 rjl OFFLINE
rjl
  • 12 Thanks
  • 15 posts
Posted September 25, 2012 - 07:39 PM
Thanks for the detailed instructions. Sure enough I had a broken spring and using your part numbers and instructions helped to resolve my problms. I do have one more issue I am wondering if you could assist. When I had the transmission back together I could not turn the drive pully by hand. I started taking it back apart then I noticed the drive pully turned more freely just by loosening the bolts. I have not torqued anything down yet but I know if I do the drive will not turn by hand as it did before. Do I have to split the transmission again or will this free up with use?
#43 MH81 OFFLINE
  • 30054 Thanks
  • 29761 posts
Posted September 25, 2012 - 07:47 PM
It sounds like something is in a bind in there. I would open it up just to make sure.
You might be able to turn the pulley with the case loose and go thru the gears, whatever it is might drop into place, but it's probably worth it to make sure all is well with the case apart.
#44 rjl OFFLINE
rjl
  • 12 Thanks
  • 15 posts
Posted September 25, 2012 - 07:52 PM
Once I had things turning I would smack the houseing with a rubber mallet while turning the drive. Then I would use a nut driver to tighten the bolts. I thought it was helping but still seems too tight. After work tomorrow I will open it back up again.
Thank you for the quick reply.
#45 NUTNDUN OFFLINE
  • 10446 Thanks
  • 15622 posts
Posted September 25, 2012 - 08:06 PM
It has been so long and my memory isn't the best since I torn mine apart. I would definitely make sure it spins without binding before trying to run it with it binding. Do you have the gasket that goes between the housing halves?
