Ranch King Pro 16.5hp 42" hydro problem
12 replies to this topic
#1 rippinryno OFFLINE
rippinryno
  • Banned
  • 11 Thanks
  • 104 posts
Posted April 20, 2015 - 08:15 AM
The deck belt broke.  I put a new deck belt on this one, same size and everything it is on right and tension appears to be good.  My question is, what engages the spring loaded tensioner pulley?  Mine is under there and I can push it by hand and put tension on the belt but none of my foot levers or the speed control move that thing, is it just supposed to sit by spring?  The issue I'm having with this mower is that I can't get it to roll freely, even when i disengage the trans from the rear, it won't roll free.  It fires right up runs great but doesn't move at all when i put it in drive or reverse.  I can't get it to move at all.  The brake does not appear to be stuck.  It's actually slightly loose.  And if i depress the brake pedal it will allow me to move the forward control knob forward, however after i let the brake out the mower doesn't go anywhere.  What is wrong with the transmission.  I'm wondering if it's still not fully engaged or soemthing?  Also, when i have it jacked up i turn one wheel and the other wheel goes ina  different direction, is that normal?
thank you in advance guys.
#2 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted April 20, 2015 - 08:37 AM
Was it working correctly before you replaced the deck belt? Unless it's posi-traction that is normal.
#3 boyscout862 ONLINE
  • 13,559 Thanks
  • 9,433 posts
Posted April 20, 2015 - 09:06 AM
I would suspect the brake pads are hanging up. I've seen it on dozens of tractors in the spring when the parking brake was on for the winter. I would also suspect that the linkage may be hanging up. Good Luck, Rick
#4 rippinryno OFFLINE
rippinryno
  • Banned
  • 11 Thanks
  • 104 posts
Posted April 20, 2015 - 10:07 AM
Ok, i'll take a look at this again tonight fellas.  I appreciate the replies.  I will also snap some pics to show you guys what i'm talking about.  The belt does not spin on the front or the rear, when the machine is running it doesn't spin, does that mean i'm not attached somewhere or not egnaging properly.
#5 rippinryno OFFLINE
rippinryno
  • Banned
  • 11 Thanks
  • 104 posts
Posted April 20, 2015 - 06:36 PM
Does all this look normal guys.  i checked linkage things seem to be working, i'm concerned about the brake rotor being loose and the transmission disengage not working properly on the shaft that goes into the tranny there.the belt is spinning as well as the transmission is spinning.  So i can see the transmission fan on the pulley spinning properly but cannot get any movement.
IMG_20150420_171342_066_zps8saa55th.jpgIMG_20150420_171512_702_zpsnpeqxlpg.jpgIMG_20150420_171526_041_zpszpceyl1g.jpgIMG_20150420_171537_072_zpsklv5jb7i.jpg
#6 rippinryno OFFLINE
rippinryno
  • Banned
  • 11 Thanks
  • 104 posts
Posted April 21, 2015 - 08:52 AM
does anybody know what could cause the tansmission pulley to spin just fine but it won't move?
#7 KennyP ONLINE
  • 40,984 Thanks
  • 47,152 posts
Posted April 21, 2015 - 08:58 AM
Could be something inside gave out.
#8 rippinryno OFFLINE
rippinryno
  • Banned
  • 11 Thanks
  • 104 posts
Posted April 21, 2015 - 10:11 AM
would no or low fluid cause it not to engage or move at all?  it doesn't whine or anything, motor doesn't bog when i throw it in gear, but i know for sure tha the pulley on the hydro is spinning.
#9 VTXrider OFFLINE
VTXrider
  • 545 Thanks
  • 396 posts
Posted April 21, 2015 - 11:53 AM
The input shaft could be broken. The brake rotor should not have grease on it. May be a problem there.
If all looks well with the belts, I would say the trans is in need of repair.
Edited by VTXrider, April 21, 2015 - 11:55 AM.
#10 rippinryno OFFLINE
rippinryno
  • Banned
  • 11 Thanks
  • 104 posts
Posted April 21, 2015 - 12:01 PM
yeah tons of grease and i can see greese where the shaft goes into the trans.  bummer
#11 rippinryno OFFLINE
rippinryno
  • Banned
  • 11 Thanks
  • 104 posts
Posted April 27, 2015 - 08:08 AM
not sure where to go from here.
#12 KennyP ONLINE
  • 40,984 Thanks
  • 47,152 posts
Posted April 27, 2015 - 09:10 AM
Might be stuck in neutral?
#13 stubbysteve OFFLINE
stubbysteve
  • 54 Thanks
  • 107 posts
Posted August 16, 2015 - 01:32 PM
I know this is a old post but did it ever get figured out? If not what is the model number of the tractor?
