John Deere 420 charge light
2 replies to this topic
#1 jwinfrey OFFLINE
jwinfrey
  • 2 Thanks
  • 10 posts
Posted March 19, 2011 - 08:15 PM
I cannot get the charge light to go off on my 420 it has a new battery and my regulator is getting 50 volts ac at wot and putting out 12.9 volts dc at wot. is my regulator messed up or any suggestions
#2 ducky OFFLINE
  • 1,989 Thanks
  • 4,108 posts
Posted March 19, 2011 - 09:54 PM
It appears charging system is working to a point. A little low on volts but should maintain the battery.
Put a volt meter across the battery and read the voltage. Then start the tractor and see if the voltage rises as the tractor runs.
I have a 316 with the circuit board in the dash. Hate it just like to do things old school. (Volts and Amps)
#3 Gary400 OFFLINE
Gary400
    JD,junkie
  • 225 Thanks
  • 768 posts
Posted March 26, 2011 - 08:06 PM
my 318 charge light used to come on for a short time then go off then back on then off then it stayed on and would not go off . i checked and it was charging but the light was on so i unplugged the wires to the light put a little contact grease on them plugged them back on and the light went out . you may try that could be just the connection on the light it self .
