Modern Engine oil question
bolens wisconsin tra-10d 1050
24 replies to this topic
#1 MrFixit1599 OFFLINE
MrFixit1599
  • 82 Thanks
  • 79 posts
Posted April 19, 2015 - 07:00 PM
I have a Bolens 1050 that I bought a few years ago for $400 dollars with several attachments, weights, chains etc.  Well, I had been using it year round and finally decided it was time to go through everything like I had when I first got it.  Rear end play, lubrication, oil changes etc.
My question is, the manual calls for 3 different weights of oil depending on the season, SAE 30 for summer, 10W-30 for fall, 5W-20 for winter (I live in Wisonsin).
It seems to me that there should be a suitable modern oil that would work year round without having to change the oil 3 times a year.
On a side note it leaks oil around the head, so I replace oil frequently enough that I doubt I would ever have to actually change the oil, just change the oil I am adding to it.  That will get addressed eventually.
  • Maerskn said thank you
#2 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted April 19, 2015 - 07:05 PM
I have always ran 10W-30 all year round in mine, My Grandfather did the same for his machines for 30+ years.
I would stick to the regular dino oil and not go synthetic.
I would definitely take care of that leak though!
  • boyscout862, superaben and propane1 have said thanks
#3 KC9KAS OFFLINE
KC9KAS
  • 5535 Thanks
  • 4770 posts
Posted April 19, 2015 - 07:18 PM
Fix the head gasket and use straight 30 weight all year....unless your machine sits outside in the winter....then you would need a thinner oil.
#4 petrj6 OFFLINE
petrj6
  • 4097 Thanks
  • 2370 posts
Posted April 19, 2015 - 07:35 PM
:ditto: :yeah_that: :iagree:  I run straight SAE30 weight year round and have never had trouble.  get that leak fixed and you will be much happier.
#5 fj5gtx OFFLINE
fj5gtx
  • 3 Thanks
  • 4 posts
Posted April 19, 2015 - 07:39 PM
worthwhile changing the oil, there is no filter ... removing the oil removes the contaminants.
#6 chris m OFFLINE
chris m
  • 3350 Thanks
  • 4069 posts
Posted April 19, 2015 - 07:54 PM
I agree, 10w-30 or SAE 30 are both a good choice for year round use. I also agree that you should fix the leak and change the oil. Or at minimum change the oil at regular intervals.
Even though you are adding new oil often, the dirty sludge will still remain in the bottom of the engine. One thing to remember is that oil does not only lubricate these engines but it also acts as a coolant.
Good luck :thumbs:
  • boyscout862 and sodisr have said thanks
#7 chieffan OFFLINE
  • 16613 Thanks
  • 9091 posts
Posted April 19, 2015 - 08:11 PM
Straight 30 weight oil is getting hard to find other than 30 gallon drums. Two brands I use to use, Northland and one other do not have it in anything less than 30 gallon any more. Go to the multi viscosity like 10W-30. If your concerned about getting to thin in hot weather add a cup of Lucas Oil Treatment. Used it all the time in my old 400 IH tractor and in the hydraulic system on the baler accumulator.
#8 superaben OFFLINE
superaben
    Con Man
  • 7672 Thanks
  • 5677 posts
Posted April 19, 2015 - 08:25 PM
Most good small engine shops have straight 30 if they are worth their salt.
Ben W.
  • Bolens 1000 and boyscout862 have said thanks
#9 propane1 ONLINE
propane1
  • 13644 Thanks
  • 6005 posts
Posted April 19, 2015 - 08:32 PM
I used to use 30 in summer 10w-30 in winter. I decided to go to 10w-30 all year. For some reasons, one is it's easier to buy almost any where, 30 is not, two, it is less expensive and three, one of my engine manuals said that, you can use 10w-30 year round, just check it more often. Noel.
#10 fj5gtx OFFLINE
fj5gtx
  • 3 Thanks
  • 4 posts
Posted April 19, 2015 - 08:34 PM
Tractor Supply always carries SAE30
Edited by fj5gtx, April 19, 2015 - 08:35 PM.
#11 adamjd200 OFFLINE
adamjd200
  • 2132 Thanks
  • 2233 posts
Posted April 19, 2015 - 08:36 PM
Can go to TSC or Advance Auto and get gallon jugs of Shell 30w, wish they had 5gal instead as we use it in the farm tractors too.
#12 Rainier OFFLINE
Rainier
  • 682 Thanks
  • 557 posts
Posted April 19, 2015 - 08:44 PM
I always change my oil. I use sae 30 Castro. This has always worked well.
#13 Toolfoole OFFLINE
Toolfoole
  • 271 Thanks
  • 145 posts
Posted April 19, 2015 - 10:38 PM
I just bought SAE HD30 at K-Mart today @ $2.99/Qt.
  • boyscout862 and propane1 have said thanks
#14 JDBrian OFFLINE
  • 9682 Thanks
  • 14162 posts
Posted April 20, 2015 - 07:48 AM
If you do want to go synthetic Amsoil males a oil specifically for small engines that replaces 30w or 10W30.
#15 KC9KAS OFFLINE
KC9KAS
  • 5535 Thanks
  • 4770 posts
Posted April 20, 2015 - 10:38 AM
And Rural King
Also tagged with one or more of these keywords: bolens, wisconsin, tra-10d, 1050
