new to Powerking 2418 owner!
7 replies to this topic
#1 bretts OFFLINE
bretts
  • 5 Thanks
  • 7 posts
Posted April 19, 2015 - 12:08 PM
:wave: First post here great to see all the fellow enthusiasts!
:wave: Well drove 4,5 hrs to get my latest tractor  after reading up on it here thanks guys!
It has the Kohler 361 but ran smooth and had a very clean head and block , two transmissions, tiller mowing deck,( to be researched about the install/swap procedure),a bunch of belts , and a bar with holes in it for the three point not sure if its a current dimension hoping it will hook to a cultivator or plow :thumbs:
I heard there are replacement engine if need be but not sure of my options in that department
well off to change oils and put it to work!
  • Gtractor, A.C.T., Genem and 1 other said thanks
#2 A.C.T. OFFLINE
A.C.T.
    Another Classic Tractor
  • 2,364 Thanks
  • 2,496 posts
Posted April 19, 2015 - 12:20 PM
Welcome!  Cant wait to see pics.
#3 countryboy88 OFFLINE
countryboy88
  • 102 Thanks
  • 144 posts
Posted April 19, 2015 - 01:00 PM
Welcome and  :wewantpics:   they will also help with you changing implements.  :D
#4 MNGB ONLINE
MNGB
  • 2,104 Thanks
  • 1,402 posts
Posted April 19, 2015 - 03:32 PM
Hi Bretts, congrats on your new tractor but  :wewantpics:
My PK has the K361 and its a good running engine and I really like the PK.
#5 EconChuck OFFLINE
EconChuck
  • 252 Thanks
  • 289 posts
Posted April 19, 2015 - 04:26 PM
Hi, The engine in that tractor has already lasted 30+ yrs if original to the tractor.
Keep it clean it will probably last many more.
The easiest and least expensive replacement engine is the 14 hp K321 Kohler. If concerned start
looking for a replacement core engine from a PK.
Good luck.
Chuck
#6 bretts OFFLINE
bretts
  • 5 Thanks
  • 7 posts
Posted April 21, 2015 - 10:29 AM
Thanks guys we broke virgin ground yesterday on two good sized beds and it took four passes but it did it! super happy about it so just ordered 50 cherry trees and 60 honey berry bushes! I promise next time out I will take pictures lol, got some compliments on her already from the neighbors
#7 bretts OFFLINE
bretts
  • 5 Thanks
  • 7 posts
Posted May 19, 2015 - 11:00 AM
well She broke hard virgin land and got a new drive shaft a new u joint and a couple welds on the tiller cover but she did it! saved a bundle on bigger equipment! now to take apart the wormgear shaft to check for the latest weak link btw the mower is a fine piece of equipment!
Edited by bretts, May 19, 2015 - 11:01 AM.
#8 Austen ONLINE
Austen
  • 1,623 Thanks
  • 892 posts
Posted May 26, 2015 - 02:04 PM
Welcome! It looks like you have a lot of land to use it with too!
