SS18 Repower Onan 18HP to Onan 24HP
22 replies to this topic
#1 Onanparts OFFLINE
Onanparts
  • 95 Thanks
  • 42 posts
Posted April 18, 2015 - 03:11 AM
I saved this 1976 SS18 from the scrapman several years ago. Previous owner said the engine was seized up. He wanted it out of his way ASAP and offered to deliver it, of course I said I'll take it!
Discovered the starter was stuck. About 10 minutes to cure that issue and it fired up no problem. It had been sitting for a long time so a carb cleaning and basic tune up and it was running smooth. A 48" deck was included with about a dozen new blades. It's a bit long in the tooth as far as looks but has been a solid workhorse the last few years.
A restoration is planned and even though the 18HP Onan BG engine runs perfect I have a P224G 24HP engine I'm rebuilding and will swap it in this year to repower it the proper way, at least in my opinion.  :wave:
  • rustyoldjunk, MH81, KennyP and 4 others have said thanks
#2 jhn9840 ONLINE
jhn9840
  • 375 Thanks
  • 356 posts
Posted April 18, 2015 - 03:17 AM
Looking forward to following along on this one. Should be interesting.
jhn9840
John
  • tinbender7 said thank you
#3 Onanparts OFFLINE
Onanparts
  • 95 Thanks
  • 42 posts
Posted April 18, 2015 - 03:31 AM
jhn9840
John
It will be a tight fit getting the 24HP big block in there but I have a big hammer, torch, welder and various implements of destruction....:) Production order for the Onan BG pictured.
  • jhn9840 said thank you
#4 1oldbuzz OFFLINE
1oldbuzz
  • 568 Thanks
  • 450 posts
Posted April 18, 2015 - 04:07 AM
Just tried this myself
that 224 is to big
If you stretch the frame 5 inches it will work
another option is to turn the engine so the crank
is parallel to the frame and then feed to a BGB then maybe
good luck with the project
#5 KennyP ONLINE
  • 38,453 Thanks
  • 45,965 posts
Posted April 18, 2015 - 04:20 AM
I'm going to lurk on this! Never seen a P224.
Onanparts, do you have access to a good B48G Service manual? I have one that I found online, but it is not really complete.
#6 jms180 ONLINE
jms180
  • 1,518 Thanks
  • 1,568 posts
Posted April 18, 2015 - 07:31 AM
sounds like a good project. The P224 is a monster engine with power
#7 toppop52 OFFLINE
toppop52
  • 5,272 Thanks
  • 4,768 posts
Posted April 18, 2015 - 07:42 AM
If you get it in and working, the only problem will be traction, those things put out enough torque to twist the earth!
#8 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,009 Thanks
  • 4,416 posts
Posted April 18, 2015 - 07:48 AM
I'm in to follow this. WooHoo.
#9 glgrumpy OFFLINE
  • 8,617 Thanks
  • 7,923 posts
Posted April 18, 2015 - 07:56 AM
Won't the drive shaft be way big on that engine??  OR, is it just a pulley change then?  Stock belt covers and stays probly won't fit then? Mule drive area?   Have no idea what engine is myself. Question for those using term "BGB" and not sure what that is?? I see it alot on Bolen's postings.
#10 KennyP ONLINE
  • 38,453 Thanks
  • 45,965 posts
Posted April 18, 2015 - 08:21 AM
BGB is a bevel gear box. No drive shaft on these tractors.
  • tinbender7 and Sawdust have said thanks
#11 Onanparts OFFLINE
Onanparts
  • 95 Thanks
  • 42 posts
Posted April 18, 2015 - 12:21 PM
that 224 is to big
I have a really BIG hammer!
What is the manual part number? 965-0767 is the Onan one I have. JD has one, CTM2 that has more detail and good pics. It covers the B43E, B43G, B48G, T260G, P218G and P220G. MTF has or had it in their free download reference library section. Or I can email it to you.
The Onan manuals are really geared towards anyone that has been there and done that and just needs a refresh of the old memory bank...:) The JD manual is very detailed and suitable for anyone, first timer or many timer.
#12 KennyP ONLINE
  • 38,453 Thanks
  • 45,965 posts
Posted April 18, 2015 - 01:00 PM
I haven't a clue what the manual # is. This is the one we have here. Just not very good but all we have found. Send me both through a PM here. I'll start it, just look up by your screen name at the top right. A red 1 will show shortly.
#13 Onanparts OFFLINE
Onanparts
  • 95 Thanks
  • 42 posts
Posted April 18, 2015 - 01:37 PM
Done!
#14 toppop52 OFFLINE
toppop52
  • 5,272 Thanks
  • 4,768 posts
Posted April 19, 2015 - 08:19 AM
I love Onans, nothing sounds as good and the torque output is amazing. I know they're expensive and all the other stuff, but I still love 'em!
#15 KennyP ONLINE
  • 38,453 Thanks
  • 45,965 posts
Posted April 19, 2015 - 08:59 AM
Me too!
  • toppop52 said thank you
