140 j d
4 replies to this topic
#1 jollygreen OFFLINE
jollygreen
  • 19 posts
Posted March 19, 2011 - 07:18 PM
How in the world does the rear wheel hubs come off ? I have tried a wheel puller, hit the axle where the nut starts, hit the back of the hub, also sprayed Blaster on it no no luck Thanks Guys
#2 bhts OFFLINE
bhts
  • 1,464 Thanks
  • 2,161 posts
Posted March 19, 2011 - 07:29 PM
I use a puller and tighten it up against the axle and a good hard smack on the end and they pop right off. Sometimes they are very hard to get off and will take a few times to get.
#3 MH81 OFFLINE
Posted March 19, 2011 - 07:59 PM
Is this something you dare apply heat to? If so, that might help.
#4 jollygreen OFFLINE
jollygreen
  • 19 posts
Posted March 19, 2011 - 10:14 PM
I was told its best not to apply heat it could warp Thanks
#5 jollygreen OFFLINE
jollygreen
  • 19 posts
Posted March 19, 2011 - 10:23 PM
I tried a puller with no luck, is there a lock ring in the center of the hub around the axle as you are looking at the axle and hub? Texas Wheel Horse said you have a lot of parts for a 140. I am in need of some things. Hydra transmission handle and plate, trans. dip stick, mower switch. pto light, steering wheel center cap, you can email your phone # or you could give me a call at 614-554-7737 Thanks Joe
