Sick Air Compressor
21 replies to this topic
#16 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,348 Thanks
  • 9,802 posts
Posted April 18, 2015 - 12:12 PM
Hmmmmmm. . . .           I tried it again today. The unloader would bleed off until around 60lbs. and then try unsuccessfully to start. If I bleed it down manually to 35lbs it would start okay.  Check valve?
#17 olcowhand ONLINE
  • 41,288 Thanks
  • 31,455 posts
Posted April 18, 2015 - 12:19 PM
Yep, and many times a good cleaning gets them sealing proper.
  • LilysDad said thank you
#18 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted April 18, 2015 - 03:37 PM
  Sounds like you found the problem. The unloader should only bleed air off for 10 sec at most. Check valves are usually easy to remove w/ a deep socket. You'll probably find a small piece of crud stuck in the valve.
  I'm gonna guess the check valve is behind the brass hex head plug in pic #3. It is on the main line where it connects to the tank from the pump and the unloader line connects to it.
                                    Mike
Edited by ol' stonebreaker, April 18, 2015 - 03:42 PM.
  • LilysDad and Sawdust have said thanks
#19 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,348 Thanks
  • 9,802 posts
Posted April 18, 2015 - 04:40 PM
Ah hah! I told you folks it was the check valve, didn't I?!!
There is a spring with a silicone rubber valve inside. One coil of the spring broke off and slightly damaged the rubber. I'll have to see if I can find a suitable replacement locally.
Thanks all for the education!
  • MH81 and Sawdust have said thanks
#20 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted April 18, 2015 - 05:06 PM
  Glad it's a simple fix!
                                    Mike
#21 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,348 Thanks
  • 9,802 posts
Posted April 18, 2015 - 05:09 PM
Yeah, about as simple as trigonometry.
  • Sawdust said thank you
#22 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted April 18, 2015 - 08:54 PM
If it doesn't cost much if any $ then I call it a simple fix!! That's what we're all here for is to save each other money among other things.
Mike
  • MH81 and LilysDad have said thanks
