tiller mod
11 replies to this topic
#1 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted April 17, 2015 - 11:02 AM
P9010151.JPG  ,done some work to get this tiller working again , the original reduction drive set broke inside like it broke a shear pin or some thing .so i could not get it apart without breaking the alloy case, so moded a steel tiller drive reduction into it & had to make new adapters for the tine cutter racks & new mountings & refit the engine a little different ,works good now ,want this 1 for behind the Rover Rancher
  • tractorgarden, larisaPn, laurarg3 and 1 other said thanks
#2 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted April 17, 2015 - 11:05 AM
#3 tractorgarden OFFLINE
tractorgarden
    Junk Whisperer
  • 1,294 Thanks
  • 1,443 posts
Posted April 17, 2015 - 11:28 AM
Interesting, so you are going to mount it on the back?
#4 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted April 18, 2015 - 12:30 AM
this is a pic of the tool bar i will be attaching to tiller on to & this tool bar is eclectic lift P8310145.JPG , the top linkage is not on at the moment
Edited by holdenboy1960, April 18, 2015 - 03:26 AM.
  • KennyP and trowel have said thanks
#5 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted April 18, 2015 - 07:49 PM
I like it, very creative fix with the tiller ! Nice tool bar.
#6 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted April 19, 2015 - 06:47 AM
lol that's the best part of doing scrap metal recycle for a living, get a lot of bits to make things out of . The blue bits are part of an exercise unit & most of the frames are from a tow bar style bicycle carry rack
But on that note
Question
Should i make the tiller dig in forward travel motion or drag cut against the pull of the tractor ??
  • trowel said thank you
#7 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted April 19, 2015 - 06:54 AM
thank you but my Rancher 2 tractor is only small & light only 8" tires so i don't have to rely on over kill on building attachments for it.
#8 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted April 19, 2015 - 06:55 AM
Dragging will build up in front of the tines (plowing) all the tractor mounted tillers spin in the direction of travel, the tractor simply holds the tiller back. I would add a cover over the tines. I t will hold in some of the dirt and turn the tiller into a miller type grinding the soil into fines in one pass.
#9 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted May 02, 2015 - 07:39 AM
hear your point on the for build up of rubbish ,Thank you trowel for your input on my, Q .I do have the cover for the tines but have to mod it a touch to refit it since i modded the unit
#10 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted May 09, 2015 - 04:34 AM
P9220014.JPG Alright been tinkering some more , made the ring hitch for the modded tiller to tow behind the Rover & painted it, Machinery grey .
#11 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted May 09, 2015 - 04:53 AM
Ready to till, looks great !
#12 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted May 09, 2015 - 05:29 AM
im just concerned that it might crab sideways while tilling behind the tractor
