Help with Simplicity 3108 wiring please
9 replies to this topic
#1 ktnch OFFLINE
ktnch
  • 7 posts
Posted April 16, 2015 - 04:34 PM
Hi there my first post and asking for a little help, i have bought a 3108 mower which was in quite a state of disrepear, Put a battery on turned the key and the coil started smoking, put the multimeter over the earth shut off to the coil and its 12v having traced the wires the coil earth is connected to the magneto wire behind the ign switch. had to buy a new coil as the old one was not smelling to good after that.
Also where the regulator wiring loom plugs in to the main loom the earth wire had burnt though.
Thinking i just best strip the loom and trace where wires are going as even the seat switch or pto switch have been bypassed, if anyone has a good easy to follow wiring diagram that would be a great help
thank you again
kev
#2 propane1 ONLINE
propane1
  • 8,712 Thanks
  • 4,124 posts
Posted April 16, 2015 - 05:03 PM
Welcome to the site, any pictures. Maybe a wiring diagram in the manuals section. Noel
#3 ktnch OFFLINE
ktnch
  • 7 posts
Posted April 16, 2015 - 05:39 PM
had a look at the std wiring diagrams all quite vauge
#4 GWest OFFLINE
GWest
  • 547 Thanks
  • 499 posts
Posted April 16, 2015 - 08:10 PM
One of these?
3108 (1690369) - Simplicity Riding Mower (MS), 30" Rotary Mower
3108 (1690395) - Simplicity Riding Mower (ES), 30" Rotary Mower
3108 (1690526) - Simplicity Riding Mower (MS)
3108 (1690527) - Simplicity Riding Mower (ES)
3108 (1691631) - Simplicity Rear-Engine Riding Mower
3108 (1691632) - Simplicity Rear-Engine Riding Mower, 30" Deck
3108E (1691106) - Simplicity Rear Engine Riding Mower
3108E (1691107) - Simplicity Rear Engine Riding Mower, 30" Rotary Mower
3108E (1691439) - Simplicity Rear-Engine Riding Mower, 30" Deck
3108E (1691551) - Simplicity Rear-Engine Riding Mower
Garry
#5 ktnch OFFLINE
ktnch
  • 7 posts
Posted April 17, 2015 - 02:04 AM
Atached an image of a part that is on the mower, now all wiring diagrams are saying this should not be on electric start mowers.
#6 ktnch OFFLINE
ktnch
  • 7 posts
Posted April 17, 2015 - 02:07 AM
from the stator the wire is red white stripe that goes to the ign switch, also in the same terminal is red and yellow and that goes to the engine block and is joined to a black wire that goes to the coil for cutting it out, so soon as the engines running the coil gets the 29vac from the stator.
just wondering if this is std wiring or its been tampared with before i rip the loom apart and check it all for alterations
#7 ktnch OFFLINE
ktnch
  • 7 posts
Posted April 17, 2015 - 02:18 AM
This wiring loom looks like mine 3108 (1691631)
with earth model
http://www.partstree...e-riding-mower/
#8 ktnch OFFLINE
ktnch
  • 7 posts
Posted April 17, 2015 - 02:20 AM
Also part 29 is this a rectifier ?
#9 skunkhome OFFLINE
skunkhome
  • 323 Thanks
  • 455 posts
Posted April 17, 2015 - 08:58 AM
Do you have a battery powered coil? If so you have the wrong ignition switch.
#10 ktnch OFFLINE
ktnch
  • 7 posts
Posted April 17, 2015 - 01:56 PM
no only wire is a shut off, striped the wiring right down shoved a 4 pin regulator in and only thing that does nork at the min is the seat switch for cut off just need a relay to get that working as the switch works in reverse
