MF 10/12 Hydraulic lift setup
2 replies to this topic
#1 NYMalloys OFFLINE
NYMalloys
  • 29 Thanks
  • 43 posts
Posted March 19, 2011 - 06:48 PM
Does anyone have either an MF10 or 12 with the hydraulic power lift. Mounting the pump assembly is fairly intuitive but the hookup for the cylinder is not (at least for me). All I have to go on is the diagram in the parts manual, but that doesn't show it in context to the rest of the tractor. If someone has setup instructions or photographs of it mounted, I would appreciate it. Also, the parts box has a few 3/8" belt pulleys which could mount on the engine, but I'm not sure which diameter pulley is the correct one. None of them has a part number stamping so I can't match it to the parts list. Thanks for any information or advice.
#2 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted March 19, 2011 - 07:34 PM
Take a look at agcopartsbooks.com
Sign in as guest.
Also, Twiedman has a hyraulic lift.
Sure would be interesting to see what you've got there.
How about puttin up some pics?
Might be easier for us to reckon out.
#3 FirefyterEmt OFFLINE
FirefyterEmt
  • 456 Thanks
  • 859 posts
Posted March 21, 2011 - 12:11 PM
Todd has an aftermarket electric lict, not the OE hydra lift. One of these days I will put the electric lift on mine, I plan to build it onto the 71 Hydro tractor though.
I will look at what is on my home computer and see if I have stored away any photos for you though.
