BGB part numbers
7 replies to this topic
#1 Sdhdcouple OFFLINE
Sdhdcouple
  • 143 Thanks
  • 153 posts
Posted April 16, 2015 - 04:56 AM
Anyone have bearing and seal numbers to replace all the bearings and seals in a BGB.  I have one apart and going to replace the bearing and seals in it while it is out and apart.
#2 KennyP ONLINE
  • 38,337 Thanks
  • 45,913 posts
Posted April 16, 2015 - 06:34 AM
Are all BGB's the same? I have 2 1974ish 416 shuttles with BGB's and wondering if that is the same as the earlier models?
#3 boyscout862 ONLINE
  • 12,849 Thanks
  • 9,171 posts
Posted April 16, 2015 - 07:39 AM
I have atleast three different BGBs with my Simplicitys that are 1971 and earlier. I think the one in my Snapper is different too. I think the "varidrive" made a difference on some. Check the Manuals Section. Good Luck, Rick
#4 Sdhdcouple OFFLINE
Sdhdcouple
  • 143 Thanks
  • 153 posts
Posted April 16, 2015 - 11:20 AM
ya mine would be BGB from the 700 series or the 7000 series simplicity.    I was hoping someone had rebuilt one already and had current bearing and seal numbers.
#5 skunkhome OFFLINE
skunkhome
  • 323 Thanks
  • 455 posts
Posted April 16, 2015 - 10:58 PM
http://www.simplicit..._03_LT_S_LO.pdf
  • Sdhdcouple said thank you
#6 Sdhdcouple OFFLINE
Sdhdcouple
  • 143 Thanks
  • 153 posts
Posted April 23, 2015 - 04:51 PM
skunkhome, how did I miss you posting me a link to the manual.  Thank you, I have been looking for this.  I am not sure how I missed it but I did.
thanks
#7 Sdhdcouple OFFLINE
Sdhdcouple
  • 143 Thanks
  • 153 posts
Posted April 23, 2015 - 04:55 PM
here is the problem bearing that caused my lock up.  I at 1st thought is was a solid metal trust type bearing, just used to keep alignment.  till I looked that the BGB diagram / parts blow up.  it is a needle bearing and it seized up.
it is the smaller one on the right side of the shaft.
2nd picture shows the matching bearing from the other location in the BGB housing.  I would have missed it if it was not for the parts blow up.
#8 skunkhome OFFLINE
skunkhome
  • 323 Thanks
  • 455 posts
Posted April 24, 2015 - 06:58 PM
If I were you I would put some medium strength locktite on the capscrew #14. Since they are right hand thread and the shaft turns CW they sometimes back out and tear up the cross shaft.
