Custom Hydraulic question
9 replies to this topic
#1 97fordrunner OFFLINE
97fordrunner
  • 9 posts
Posted April 15, 2015 - 11:08 AM
I acquired a JD 300 with a blown K341 Kohler which i just rebuilt and had machined to make it better than new (smoothed out the intake & exhaust ports to allow better flow, better valve springs etc.) and got it in the tractor to find out the previous owner BS'd me (which I should have known when he said he didn't tow it ) but now I find the trans axle is shot. I am looking into the option of making it a 4x4 articulated tractor but my question now is:  What are the thoughts on using the engine to strictly drive a bigger hydraulic pump and running 2 or 4 hydraulic motors to run the wheels/axles? I have been looking at Northern Tools website checking out different pumps and trying to decide if 1 pump per wheel or make solid axles and using 2 pumps and a chain drive to the axle so I could fine tune the ground speed for what I am looking for - weather that may be low speed high torque for pulling a plow or a little faster for parades etc.  Am I on a decent train of thought or is this ludicrous?
I'd like to have the hydraulic output and capacity to run a 3pt hitch, And have front outputs for a blade or other front mounted attachments.  I'm thinking a 16GPM at 3000RPM and 15.8 GPM 2575PSI motors rated for 2125in-lbs (177ft lbs) might be a good start but my biggest question is that enough torque or is that going to stall out under heavy load especially if I was to do a solid axle set up with a chain drive which would multiply the torque.
Thanks guys. I'm kind of a Hydraulic Newb when it comes to building a system
#2 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted April 15, 2015 - 11:49 AM
:welcometogttalk:
#3 97fordrunner OFFLINE
97fordrunner
  • 9 posts
Posted April 15, 2015 - 12:01 PM
Thanks. I was here years ago when I had a '59 Simplicity wonderboy but after I sold that I kind of fell off the face of the GT Talk world
#4 Cat385B ONLINE
    HAZMAT CAT
  • 14,376 Thanks
  • 10,145 posts
Posted April 15, 2015 - 02:40 PM
Did you have an account back then? Are you using your same user name?
#5 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted April 15, 2015 - 06:05 PM
Welcome back. How would you get it to turn w/o scuffing tires w/ a solid axle?
Mike
  • Bill 76 and Auburn David have said thanks
#6 TomLGT195 OFFLINE
TomLGT195
  • 4,055 Thanks
  • 2,903 posts
Posted April 15, 2015 - 07:33 PM
:welcometogttalk:
:ditto: Tom
#7 TUDOR OFFLINE
TUDOR
  • 565 Thanks
  • 507 posts
Posted April 16, 2015 - 01:37 AM
Welcome to GTTalk!!
A bigger pump relative to what? Your numbers are correct for 4 individual drive wheels. The original Sundstrand hydro flowed 14.2 gpm at 3600 rpm and could deliver up to about 800 ft-lb of torque with gear reduction for a 9 mph top speed with 23" diameter tires, if you could find enough traction to keep the tires from spinning when you started the load moving.
Try this pump, and 4 of these motors. You will also need 3 of these flow dividers, and at least one of these cushion valves.
Those motors are rated at 2108 in-lb  (176 ft-lb) of torque each at 1840 psi. Here's a hydraulic motor torque calculator.
A hydro pump is a lot easier for fine control than a fixed displacement pump with a control valve and 700 ft-lb of torque is not easy to find traction for with a GT sized machine. I've found more, but it took 1700 lb of rear end ballast. Can we say "overloaded"? There was breakage involved.
  • limebuzz and 97fordrunner have said thanks
#8 toppop52 OFFLINE
toppop52
  • 5,547 Thanks
  • 4,907 posts
Posted April 16, 2015 - 06:25 AM
I've thought about doing a 2WD using zero turn wheel motors, in fact using the whole setup from one, they often come up for sale when a commercial ztr blows a motor or some such. I've thought about it but wasn't sure I gained anything over a Sunstrand hydro through a rear differential on a front end loader.
#9 TUDOR OFFLINE
TUDOR
  • 565 Thanks
  • 507 posts
Posted April 16, 2015 - 01:49 PM
You gain maneuverability with an articulated or skid steer over a standard 2wd tractor. Ride comfort suffers somewhat and there is a higher risk of lawn damage, especially with the skid steer. A skid steer, in particular, does not lend itself to old joint and back injuries when climbing in and out.
#10 97fordrunner OFFLINE
97fordrunner
  • 9 posts
Posted April 19, 2015 - 09:24 PM
I am using the same user name as I had before i'm sure. this is the only name I have ever had in forums.
