Wiring
15 replies to this topic
#1 1964Deere ONLINE
1964Deere
  • 249 Thanks
  • 292 posts
Posted April 14, 2015 - 06:50 PM
Have an S-16H and my wiring started melting after installing a new starter solenoid. After analyzing the wiring I came to the conclusion my reset on the dash is bypassed and so are the diodes. What are they used for? Is it ok to have them bypassed?
#2 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted April 14, 2015 - 08:22 PM
If your wiring is melting, you have high amperage draw which means that if the circuit breaker was in place it would pop.
If I was you, I would check your wiring against a wiring diagram and see what is happening.  You don't want a short burning up something more expensive than a wire.
Ben W.
  • HDWildBill and KC9KAS have said thanks
#3 1964Deere ONLINE
1964Deere
  • 249 Thanks
  • 292 posts
Posted April 14, 2015 - 08:41 PM
Too late for that!!! Ariens is only brand with these diodes? Deere doesn't use them that I know of! Can you get them anywhere?
#4 1964Deere ONLINE
1964Deere
  • 249 Thanks
  • 292 posts
Posted April 14, 2015 - 09:11 PM
And I should note my circuit breakers are wired in yet
Edited by 1964Deere, April 14, 2015 - 09:12 PM.
#5 1964Deere ONLINE
1964Deere
  • 249 Thanks
  • 292 posts
Posted April 15, 2015 - 07:21 AM
Did some more research and found out that the diodes I'm talking about is actually called a an interlock module. What exactly does it do?
#6 shorty ONLINE
shorty
  • 5,291 Thanks
  • 5,171 posts
Posted April 15, 2015 - 05:25 PM
It keeps the tractor running when your bum bounces on the seat switch. One guy had built his own module. Here is the write up.  http://gardentractor...locktime-delay/
#7 1964Deere ONLINE
1964Deere
  • 249 Thanks
  • 292 posts
Posted April 15, 2015 - 09:51 PM
So this module is only there to keep the tractor running?
What exactly does the reset button on the dash reset then?
#8 shorty ONLINE
shorty
  • 5,291 Thanks
  • 5,171 posts
Posted April 16, 2015 - 02:43 PM
It has been a bit since I have messed with the wires, I forget which circuit they are in. Would you have the model number of your tractor? Then I could look for a wiring diagram.
#9 1964Deere ONLINE
1964Deere
  • 249 Thanks
  • 292 posts
Posted April 16, 2015 - 03:36 PM
It's an S-16h.
#10 1964Deere ONLINE
1964Deere
  • 249 Thanks
  • 292 posts
Posted April 16, 2015 - 03:41 PM
One wire goes to circuit breaker and the other to the interlock module. But I am but sure what it resets. The circuit breakers are automatic so is it resetting something in the module?
#11 shorty ONLINE
shorty
  • 5,291 Thanks
  • 5,171 posts
Posted April 16, 2015 - 04:12 PM
There are different wiring for different years of the S-16. Its easiest going off the model number, a six digit starting with 931_ _ _
#12 1964Deere ONLINE
1964Deere
  • 249 Thanks
  • 292 posts
Posted April 16, 2015 - 04:40 PM
931010
#13 1964Deere ONLINE
1964Deere
  • 249 Thanks
  • 292 posts
Posted April 16, 2015 - 04:41 PM
It's a 1976.. Regardless of year that reset switch should serve the same purpose.
#14 Natureboy OFFLINE
Natureboy
  • 83 Thanks
  • 98 posts
Posted April 16, 2015 - 05:40 PM
I believe the reset button on the dash re-starts the PTO if it shuts off when your butt bounces off the seat.
#15 1964Deere ONLINE
1964Deere
  • 249 Thanks
  • 292 posts
Posted April 16, 2015 - 06:16 PM
Ok thanks nature boy!
