sandblaster hose
5 replies to this topic
#1 WHdbJD OFFLINE
WHdbJD
  • 686 Thanks
  • 516 posts
Posted April 13, 2015 - 06:45 PM
I was blasting the rims for my WH project
(http://gardentractor...se-and-a-mouse/)
and noticed the hose from the tank to the nozzle was
badly cracked and splitting in many places.
Not leaking...yet...but my question is this;
Is this a special type hose , built to withstand
the abrasive media/air mix, or can I replace it
with any standard hose with the proper ID??
  • fourpines said thank you
#2 WrenchinOnIt OFFLINE
WrenchinOnIt
  • 3,585 Thanks
  • 968 posts
Posted April 13, 2015 - 07:51 PM
I was blasting the rims for my WH project(http://gardentractor...se-and-a-mouse/) and noticed the hose from the tank to the nozzle wasbadly cracked and splitting in many places.Not leaking...yet...but my question is this;Is this a special type hose , built to withstandthe abrasive media/air mix, or can I replace itwith any standard hose with the proper ID??
Need more info, is it a pressure pot , or siphon feed with air to the gun and the hose just draws the media from the canister? Pressurized pot requires a special high pressure hose that resembles a hydraulic line, a siphon feed (usually a clear hose) does not , and is not pressurised therefore you can go to your local hardware , TSC, etc. get the right diameter and I'd get the heaviest wall tubing they had. ( should last longer)
Edited by WrenchinOnIt, April 13, 2015 - 08:01 PM.
  • WHdbJD, boyscout862 and fourpines have said thanks
#3 WHdbJD OFFLINE
WHdbJD
  • 686 Thanks
  • 516 posts
Posted April 14, 2015 - 06:42 AM
Thanks for the answer! Its a pressure pot so I will need the high pressure hose.
#4 fourpines OFFLINE
fourpines
  • 100 Thanks
  • 29 posts
Posted April 16, 2015 - 12:32 AM
Thanks I have had the same question.
Mike S.
#5 dodge trucker ONLINE
dodge trucker
  • 2,452 Thanks
  • 3,133 posts
Posted April 19, 2015 - 09:18 AM
I have a blasting cabinet (siphon feed) and I got it with a hunk of garden hose to feed the gun, every couple years that garden hose deteriorated from the inside out and I gotta replace it as it then starts to collapse on itself and not suck sand... once every couple years, I can deal with that...
#6 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted April 19, 2015 - 09:33 AM
I get my hose from my local auto parts store. Its a Napa franchise,  fairly expensive like 60 or 70 dollars for a 10 footer, but its pretty thick and tough stuff. Mine usually wears out on the inside near the tank and after I cut it off a couple times, I get a new one.
  • WHdbJD said thank you
