Is there a T-92 Transmission Rebuild thread ?
5 replies to this topic
#1 Glenn Ayers OFFLINE
Glenn Ayers
  • 63 Thanks
  • 86 posts
Posted April 13, 2015 - 05:28 PM
Particularly looking for a part number for SEALED front & rear bearings that fit this tranny. Anyone have info on this ? How about a source for the loose Needle/Roller bearings that go in between the input/output shaft interface ?
Thanks !
~Glenn
#2 KennyP ONLINE
  • 38,447 Thanks
  • 45,963 posts
Posted April 13, 2015 - 05:52 PM
Someone may know them, but I think you can find them in this manual. Page 4 is a tranny breakdown.
  • boyscout862 and Glenn Ayers have said thanks
#3 glgrumpy OFFLINE
  • 8,617 Thanks
  • 7,923 posts
Posted April 13, 2015 - 06:43 PM
I had those numbers around, not sure now. Common numbers most auto or bearing stores. One in front needs that lock ring slot, usually comes with ring, but new one is too large and wont' let bearing cover fit over it and so you need to keep the old one to re-use if not damaged removing it. The center ones are hard to find. Mission manufacturing the PK people in S. IN have those I think, but costly. I've seen places wanting 4 or 5 dollars a PIECE for those,  yet others cheaper. Think you need 13 rollers if I recall. Bearings Inc or what ever it is now didn't have correct size. I ordered some within .001 of my measurements and the DON"T fit. Be careful of what you order if by size. Seems Jerry Frank in Tex might have, address is on here in PK forums recently.  There is a Crosley parts place that has some parts, have to ask others for that name. There is a trans group that just was sold and moved west for parts, again maybe others have that name?  Yahoo group/Power King Tractors has some of this info on it if you join.  More fellas on there that have the info too.  No name on here might be helpful and David Brown. They will probly be along soon. Should be blow-ups and parts diagrams in the new group of PK stuff being put on here in manuals now.
  • Glenn Ayers said thank you
#4 Username OFFLINE
Username
  • 2,072 Thanks
  • 1,425 posts
Posted April 13, 2015 - 07:22 PM
6205 RSNR or 6205 2RSNR and 204PP for the sealed bearings.
  • KennyP and Glenn Ayers have said thanks
#5 Glenn Ayers OFFLINE
Glenn Ayers
  • 63 Thanks
  • 86 posts
Posted April 14, 2015 - 03:28 AM
Thanks Grumpy & Username !!!!
~Glenn
#6 Glenn Ayers OFFLINE
Glenn Ayers
  • 63 Thanks
  • 86 posts
Posted April 14, 2015 - 03:43 AM
Thanks for the Manual   Kenny !!!
~Glenn
