Edited by WrenchinOnIt, April 14, 2015 - 06:39 PM.
Hydro vs. gear drive
#16
OFFLINE
Posted April 13, 2015 - 08:23 PM
- wilberj, Alc, blackjackjakexxix and 1 other said thanks
#17
OFFLINE
Posted April 13, 2015 - 08:24 PM
Gear for personal, hydro for work.
#18
OFFLINE
Posted April 13, 2015 - 09:08 PM
#19
OFFLINE
Posted April 14, 2015 - 06:31 AM
One thing I'm sure of, there is no one right answer, kinda like politics and religion and pickup truck brands!
- blackjackjakexxix, propane1 and AA Hayes have said thanks
#20
ONLINE
Posted April 14, 2015 - 08:49 AM
I'm a hydro person but always try and use a gear drive for tilling. I am now using a self powered pull behind tiller with a gear drive tractor and it works great. Used a Cub 125 hydro with a mounted tiller for years and I was having to change the hydro settings all the time. With the gear drive I just set it once at the end of the garden and let it go until the other end. My garden is 175' long.
- blackjackjakexxix, WrenchinOnIt and propane1 have said thanks
#21
OFFLINE
Posted April 14, 2015 - 06:42 PM
They both are good. I think it is up to the user as to preference. I like to drive the gear tractors for fun and use my hydrostatic for mowing, blowing, plowing and most work.
- WrenchinOnIt and propane1 have said thanks
#22
OFFLINE
Posted April 14, 2015 - 08:57 PM
I'll take that bait--Dodge!!! LOL
- blackjackjakexxix said thank you
#23
OFFLINE
Posted April 14, 2015 - 09:35 PM
Had one Dodge for about 2 months got rid of it. No power and a gas hog. Back to the gold old Chevy. Back on topic, Bay all means plow your ground first. If that is not an option rent a tractor and tiller and break new ground first. Let it lay a while and then use your GT & tiller and you will get along fine. I plow my garden first with a Gardener and plow. Sure not fancy but fun and it gets a good job done. Then the 1053 & tiller and follow it with the BCS tiller for a finish job. Those GT mounted tiller only do half a job, they only turn half as fast as a good job requires. My hydro is a Ford and in the shed for the 2nd year. All 3 GTs are 3 speed with Hi-Lo. Just my opinion.
- blackjackjakexxix, WrenchinOnIt, propane1 and 1 other said thanks
#24
OFFLINE
Posted April 15, 2015 - 11:35 AM
i have an Allis tiller but have not put it behind my Simplicity yet. I'm leaning towards selling it and getting a self powered pull behind for my Suburban. I agree with you that it's tine speed that makes a better seed bed and I would think I could get more speed and crawl with the Suburban.
And you're right about Dodges loving gas.
- AA Hayes said thank you
#25
OFFLINE
#26
ONLINE
Posted April 15, 2015 - 08:37 PM
I'm using a self powered tiller behind my GT-18. I had my doubts when I came across it but that was unfounded. I really like it. So much so that the cub Cadet with the mounted tiller doesn't get used any more. For some reason it doesn't seem to push the tractor like the mounted tiller did. I did raise the air filter up though. It would get filthy in an hour the way it came.
I would suggest an electric or hydraulic lift as one arm lifting is very hard.
- propane1 said thank you
