Hydro vs. gear drive
#1
OFFLINE
Posted April 13, 2015 - 01:51 PM
I am looking for opinions on tilling with the hydro trans vs. the gear drive. I have about a 1/4 acre garden.
- propane1 said thank you
#2
OFFLINE
Posted April 13, 2015 - 01:53 PM
I prefer hydro for most everything, but especially with a front end loader & tiller. With the infinite speeds, you can go slow as you want.
- EricFromPa, boyscout862 and TomLGT195 have said thanks
#3
ONLINE
Posted April 13, 2015 - 02:51 PM
Ya tilling is Alot easier with a Hydro.I was constantly being pushed around by the tiller on my 1050 and G11/1254 even though I had wheel weights and tire chains on both and both were in Lo range.I have a fence around my garden so Alot of shifting between reverse and forward to.
And the Hydro lift on a Large frame will save your arm from wearing out.Tube frame tillers get a bit on the heavy side when you are tilling a big garden and having to lift it every pass you make.
- Alc, boyscout862 and AA Hayes have said thanks
#4
ONLINE
Posted April 13, 2015 - 03:18 PM
I find my MF12 gear drive works much better than my Ford lgt 165 hydro for tilling. The ford bounces you head. Always playing with the foot pedal hydro to keep it steady, the MF12 gear is as smooth as can be. Set it and forget it. Just my opinion, Noel
- DH1, Alc and Cvans have said thanks
#5
OFFLINE
Posted April 13, 2015 - 03:34 PM
I'm also spoiled with hydraulic lift but quite honestly, for the limited amount of tilling you have, it's not too much up and down for the Armstrong. if you were pushing or blowing snow I would vote hydraulic lift every day of the week. lots of up down up down up down... Up down up down with those.
- DH1, Cvans, propane1 and 1 other said thanks
#6
OFFLINE
Posted April 13, 2015 - 03:35 PM
- Bolens800uk said thank you
#7
OFFLINE
Posted April 13, 2015 - 03:37 PM
#8
OFFLINE
Posted April 13, 2015 - 04:34 PM
Gear drive for Tiller is better IMO
Hydro from my experience's doesn't hold a slow steady speed as good as a Gear drive does when using a Tiller
#9
OFFLINE
Posted April 13, 2015 - 05:04 PM
I prefer gear over hydro. These are the units I've had tillers on:
1. JD 212 (geared)
2. Homelite T15 (hydro)
3. Bolens G152 (geared)
The tiller would push the Homelite, the JD would only move if tilling hardpack or sod, the Bolens ain't gettin' pushed around by anything.
No pic of the JD? WTH?
#10
OFFLINE
Posted April 13, 2015 - 05:09 PM
I think i will get the tiller for the ht but keep looking for one for my 1050 as well. I have blowers blade and decks for all my tractors, might as well have a tiller for each one as well
I run a 48 tiller on a 1476 I would pick the HT over a tube frame but I would say plow first if you can...
http://gardentractor...ing#entry461976
Edited by wilberj, April 13, 2015 - 05:13 PM.
- WrenchinOnIt, propane1 and AA Hayes have said thanks
#11
OFFLINE
Posted April 13, 2015 - 05:13 PM
Sure, keep grabbing stuff, and stuff it in a shed. Even if it might never see the light of day ever again. Works for Jerome!
- AA Hayes said thank you
#12
OFFLINE
Posted April 13, 2015 - 05:14 PM
You will be eating those words soon!
- Cat385B said thank you
#13
OFFLINE
Posted April 13, 2015 - 05:49 PM
Works for me, too!
#14
OFFLINE
Posted April 13, 2015 - 07:55 PM
- WrenchinOnIt and AA Hayes have said thanks
#15
OFFLINE
Posted April 13, 2015 - 08:04 PM
I don't have a plow, wish I did but I don't see it being in the budget this year.
To bad the ht20 doesn't have the hi/lo trans. I expect it to push me when tilling sod but not the already tilled part, hopefully.
