Nothing like a freebie
27 replies to this topic
#16 glgrumpy ONLINE
  • 8,362 Thanks
  • 7,748 posts
Posted April 18, 2015 - 09:17 PM
What's the story on this? Been waiting for the pictures!  No deal then?  Wanna see, wanna see!  If no deal, go over and take pictures just to let us see what the heck it was. Might be satisfying for the rest of us, ha!
#17 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,192 Thanks
  • 5,790 posts
Posted May 01, 2015 - 02:57 PM
Finally got it home. Pretty much a POS.KIMG0034.jpg KIMG0035.jpg KIMG0036.jpg KIMG0037.jpg
  • sacsr, MFDAC, backwoods and 3 others have said thanks
#18 Sawdust OFFLINE
Sawdust
  • 5,363 Thanks
  • 3,261 posts
Posted May 01, 2015 - 05:36 PM
Glad you got it. Don't know much about these but looks like a good project. I heard a guy say one time "if it casts a shadow it's worth having".
#19 BTS ONLINE
BTS
    Make Stuff Up
  • 3,911 Thanks
  • 2,305 posts
Posted May 01, 2015 - 11:26 PM
:worship: WOW!!!!! That's nice! I could use a set of those rear tires!
#20 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,192 Thanks
  • 5,790 posts
Posted May 02, 2015 - 06:48 AM
One pair is probably going on the Cub. Same size.
#21 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,192 Thanks
  • 5,790 posts
Posted May 04, 2015 - 01:29 PM
Engine is free, transmission is stuck.
#22 JBRamsey ONLINE
JBRamsey
  • 1,312 Thanks
  • 761 posts
Posted May 04, 2015 - 04:56 PM
Doesn't look like a POS to me.
  • wilberj and holdenboy1960 have said thanks
#23 wilberj ONLINE
wilberj
  • 4,841 Thanks
  • 5,514 posts
Posted May 04, 2015 - 05:25 PM
:ditto:
#24 wvbuzzmaster OFFLINE
  • 4,714 Thanks
Posted May 04, 2015 - 05:27 PM
Nice haul. Tires alone were worth it.
#25 glgrumpy ONLINE
  • 8,362 Thanks
  • 7,748 posts
Posted May 04, 2015 - 07:45 PM
Surely not a POS!!  I've bought much worse myself.  I think it looks pretty good. Trans stuck is not big issue, common on these, and easy to fix. Building up end ball on shifter with weld and grind down to size again. Tans top comes off easy if you remove the tunnel tin, the harder part and you can sometimes shift the gears back by hand and  put cover back on and it works for awhile with careful shifting of the pattern and slow easy throws. If you look at my Avatar, I don't have the tunnel on mine, put in plate floor and trans is always open to work on if needed. 2nd tractor I did that too. You have to make diff place for battery and oil tank to ride on tho, as it sets on the pan. Heck, if you don't want it, save it for ME, I'll figure out how to get it home....... :dancingbanana: I think you done good! Duals are nice, can sell the adapters easy if you don't wish to use them. Yes, they are cub wheels at both ends.
  • KennyP and holdenboy1960 have said thanks
#26 glgrumpy ONLINE
  • 8,362 Thanks
  • 7,748 posts
Posted May 04, 2015 - 07:51 PM
Pix too dark, does it have the hydraulics and 3 point on it?  This is a long hood, so electric pto in front and later model year, the best decade of the tractor. Lots of parts on epay and other places, won't have any issues with that. Bearings and bushings are all stock items, get anywhere. Get the serial off the tag on dash or front grill if still there. Just a decal, not stamped.  Sometimes under foot  tin  is a stamped number in frame top, but not always. Again, the tin tunnel has to come off to see. We have charts to look up  year. Might be one here now with all the PK stuff loading up  in the manuals section.
I see mule drive for mower is still hanging on there, you get a deck? That drops off pretty easy, if you take off, keep it handy, don't junk.  A snow blade is easy to get and mounts on same blocks under the frame if you wish for one of those. Maybe PO has the deck or a blade laying around in weeds or a barn?
Edited by glgrumpy, May 04, 2015 - 07:55 PM.
#27 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted May 10, 2015 - 07:54 AM
like MF  35's & 65's locks 2 gears at once common prob
#28 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,192 Thanks
  • 5,790 posts
Posted May 11, 2015 - 07:55 AM
Kohler, not Briggs. 3 point hitch, no attachments. May mess with it some next week. Left tie rod end snapped off while loading.This thing has more rust than a "square" body Chebby truck, that's saying a lot.
