Brinly 12" Plow Redo
20 replies to this topic
#1 KennyP ONLINE
  • 40,109 Thanks
  • 46,756 posts
Posted April 13, 2015 - 04:52 AM
Since the 10" looks decent now, thought I would get the 12" out and pretty it up some.
Took the hitch beam off and wire wheeled it down.
Pulled the main beam off and cleaned it up.
More parts to clean and coat with Rust Reformer.
We have rain today so I am not sure what I can get to do. It will be this afternoon before I can prime anything anyway.
  • OldBuzzard, Alc, Texas Deere and Horse and 7 others have said thanks
#2 Alc ONLINE
  • 7,124 Thanks
  • 7,530 posts
Posted April 13, 2015 - 05:14 AM
Will the Rust Reformer stick to sound paint as long as it roughed up ?
 It looks good too
Edited by Alc, April 13, 2015 - 05:14 AM.
  • tinbender7, boyscout862 and Coventry Plumber have said thanks
#3 KennyP ONLINE
  • 40,109 Thanks
  • 46,756 posts
Posted April 13, 2015 - 05:42 AM
 It looks good too
It seems to be like any primer except it stops the rust from coming back through, Al. So I think it would do just fine.
  • Alc, tinbender7 and boyscout862 have said thanks
#4 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted April 13, 2015 - 07:47 AM
Damn Kenny! You're just a busy little bee!
  • KennyP and tinbender7 have said thanks
#5 CRFarnsworth ONLINE
CRFarnsworth
  • 4,978 Thanks
  • 2,218 posts
Posted April 13, 2015 - 07:53 AM
i BET THIS ONE ENDS UP JUST AS PRETTY AS THE OTHER ONE!   ($%^& caps lock)        Rick
  • KennyP and holdenboy1960 have said thanks
#6 propane1 ONLINE
propane1
  • 9,121 Thanks
  • 4,275 posts
Posted April 13, 2015 - 08:33 AM
What colour for this one ??? Noel
#7 KennyP ONLINE
  • 40,109 Thanks
  • 46,756 posts
Posted April 13, 2015 - 08:52 AM
Black & White so they match.
  • Sawdust, propane1 and holdenboy1960 have said thanks
#8 dthomp17 OFFLINE
dthomp17
  • 597 Thanks
  • 480 posts
Posted April 13, 2015 - 09:07 AM
You do good work Kenny.
#9 JDBrian OFFLINE
  • 9,642 Thanks
  • 14,157 posts
Posted April 13, 2015 - 09:13 AM
Looks good! It must be nice to be able to get back outside handwork again in some comfortable temperatures.
#10 KennyP ONLINE
  • 40,109 Thanks
  • 46,756 posts
Posted April 13, 2015 - 09:23 AM
Brian, it feels real good. Today is very HUMID, though! Drizzle most of the day it looks like. Not much gonna happen til it stops.
  • JDBrian said thank you
#11 Texas Deere and Horse OFFLINE
  • 14,862 Thanks
  • 15,511 posts
Posted April 13, 2015 - 09:26 AM
Looking good Kenny. Glad you have the time to do some work on your toys.
#12 JDBrian OFFLINE
  • 9,642 Thanks
  • 14,157 posts
Posted April 13, 2015 - 09:27 AM
If this warm weather keeps up we may be able to walk around the property in another week or so. Right now the couple of feet of snow remaining is soft and you sink in it, so we can't do much outside yet.
  • KennyP and propane1 have said thanks
#13 KennyP ONLINE
  • 40,109 Thanks
  • 46,756 posts
Posted April 13, 2015 - 09:46 AM
Thought a facelift on these would help for the show.
#14 KennyP ONLINE
  • 40,109 Thanks
  • 46,756 posts
Posted April 14, 2015 - 08:32 AM
Since the temps have dropped here some, I brought the parts inside to warm them before I do anymore. After a couple hours in here, they should be warm enough to continue and outside temps will be better. Got lots of small stuff to go through the wire wheel before they can be coated.
#15 KennyP ONLINE
  • 40,109 Thanks
  • 46,756 posts
Posted April 15, 2015 - 05:30 AM
Update! Got a lot accomplished yesterday. Had to make supper so I didn't get this posted last night. It was a bit chilly and humid, so I made a temporary heat source. Used a turkey fryer and stacked some heavy steel over the burner. Fire it it and heat the steel, then cut the burner and enjoy. Worked pretty good. The 2 middle pieces are 1" thick X 2.5" bar stock. 2 chunks of 1/4" wall 2" x 2".
Brought the 2 main sections out and got those primed so they could set a while.
Broke out the tools to clean up the small parts.
With those done, I could get the primed beams ready for the White paint. (Rustoleum  Self-Etching Primer and Gloss White) I use a fresh green scotch brite instead of sandpaper to scuff the primer.
Here's the depth wheel and coulter ready to install.
Here's the bottom section of the plow.
  • Sawdust and Coventry Plumber have said thanks
