Barn find followed me home today
52 replies to this topic
#31 KennyP ONLINE
  • 40,148 Thanks
  • 46,773 posts
Posted April 15, 2015 - 02:25 PM
Hour meter should not run if the switch is off!
  • hamman said thank you
#32 hamman ONLINE
hamman
    Homelite Owner Extraordinaire
  • 6,568 Thanks
  • 2,906 posts
Posted April 15, 2015 - 02:35 PM
I disconnected the battery cable and the hour meter stopped. After connecting the cable again it was not working. I turned the key and heard a sound like a solenoid trying to open, then the hour meter started again. Turned the key off and the hour meter stayed running. Do I have to pull the dash up to get to the back or does that plate between the bash and motor come off? Looking at the wiring diagram it shows a magnetic switch, Solenoid but I can't see it anywhere. I think it is under the dash.
If I miss my guess I think the solenoid is going, or is bad.   The other thing I don't see is the neutral safety switch.        Roger
Edited by hamman, April 15, 2015 - 02:36 PM.
#33 hamman ONLINE
hamman
  • 6,568 Thanks
  • 2,906 posts
Posted April 15, 2015 - 02:38 PM
Going back out to try to get to the underside of the dash.
#34 diesel nut OFFLINE
diesel nut
  • 760 Thanks
  • 455 posts
Posted April 15, 2015 - 03:00 PM
There's a safety circuit in the pto switch and on the brake pedal.  Both of them can work fine and then the next time you go to start it they can be bad.  If  I have a problem like that on one at work I unhook them and put a jumper wire in the plug to see if that fixes it then replace which ever one is bad.  As for the hour meter running with the key off and out thats normal.  It'll do that for a few minuets until the charge is gone in the meter every time the key is on.  The plate between the backside of the dash and the gas tank comes out with 2 bolts.  The solenoid is on the inside of the dash on the rh side.  The neutral switch is underneath on the frame and there is a tab on the brake pedal that depresses it when you push the pedal down.            Stewart
Edited by diesel nut, April 15, 2015 - 03:05 PM.
  • hamman and Sawdust have said thanks
#35 hamman ONLINE
hamman
  • 6,568 Thanks
  • 2,906 posts
Posted April 15, 2015 - 04:01 PM
I notice that there is no cooling fan on the shaft ? Is there supposed to be one on this model? I also need two new flex disc. Does any of our site sponsors sell them? Can I make them out of farm welting / belting? Thanks. I'm going back out to look for the switch. I just got done reviewing the wiring diagram.       Roger
  • MH81 and Sawdust have said thanks
#36 hamman ONLINE
hamman
  • 6,568 Thanks
  • 2,906 posts
Posted April 15, 2015 - 04:33 PM
Still can't find a switch on the brake / clutch pedal. I found a small switch with no wires attached in the middle of the tractor. It appears to be a switch for a mowerdeck? Here a re a few pictures. Thanks
Switch I found.
Front flex joint and no fan.
Rear flex joint and no fan.
#37 MH81 OFFLINE
Posted April 15, 2015 - 04:41 PM
Wish I could help, out of my league on this one.
#38 KennyP ONLINE
  • 40,148 Thanks
  • 46,773 posts
Posted April 15, 2015 - 05:07 PM
There should be a fan, IH-547749-R1 (about 2/3 down on left). The flex joints are part # 722-3000.
#39 diesel nut OFFLINE
diesel nut
  • 760 Thanks
  • 455 posts
Posted April 15, 2015 - 08:44 PM
The switch in the first pic is the one for the brake pedal.  The tab on the pedal to activate it is broken off so that's why its unhooked.  I can just see the wires for that switch in the top corner of the pic. Might want to check and make sure there connected together still because if there not it won't start.
  • hamman, KennyP and EricR have said thanks
#40 hamman ONLINE
hamman
  • 6,568 Thanks
  • 2,906 posts
Posted April 15, 2015 - 09:29 PM
Ok that makes sense. I will look at it harder tomorrow. I did see some sort of extra wiring when I was looking in there. I figured it was a jumped switch or something like that. Thanks again. I will post more after I get it running again.
I wasn't sure I was going to keep this but I kind of like how big it is and it would make a good addition to the family. Wife says I might as well keep " Cubby " see she has already named it. I liked " Dusty " for how dirty it is. Going to look for a rear lift for it so it will have a sleeve hitch for my attachments. I see it has a Deere hydro filter on it. Gotta change that.        Roger
  • Sawdust said thank you
#41 powerstroker00 OFFLINE
powerstroker00
  • 669 Thanks
  • 332 posts
Posted April 15, 2015 - 11:38 PM
that is a very good tractor. my son has a 1250,&1450, and my fnl has the 1650. we one of his from time to time will do exactly what yours is doing. its in the pto switch. when you hold the key in the start position wiggle the pto switch and see what it does. thats what my sons does. you can get a rear lift for it at a swap meet for 100-150, thats what they go for around here and you can find side panels pretty cheap too. those cubs are tanks.
  • hamman and KennyP have said thanks
#42 hamman ONLINE
hamman
  • 6,568 Thanks
  • 2,906 posts
Posted April 17, 2015 - 02:36 PM
Found a local dealer who has the PTO switch (original), flex disc (2), and the hydro fan in stock. I can't get there until next week but at least it's semi close to home and don't have to pay for shipping if I go pick it up. About $ 60.00 with tax. Comparable with Ebay and shipping and other places. Besides wife says we need to grocery shop over that way next week any way.        Roger
  • KennyP and Sawdust have said thanks
#43 KennyP ONLINE
  • 40,148 Thanks
  • 46,773 posts
Posted April 17, 2015 - 06:50 PM
Glad you found the parts that close!
#44 Sawdust ONLINE
Sawdust
  • 6,010 Thanks
  • 3,491 posts
Posted April 17, 2015 - 07:05 PM
If your wife has already named it you now what that means. I only recommend this for testing. On my MTD 990 the wiring was such a mess I had to jump the entire safety circuit until I did the ole process of elimination. I had to replace two bad switches. My solenoid was bad too...power going in but not coming out to the starter. You do have a nice tractor at a real good price too. I have one more to put back together until I can start on my 1250 so I'm just as excited as you are for you to get Cubby running.
Edited by Sawdust, April 17, 2015 - 07:08 PM.
#45 BNK OFFLINE
BNK
  • 1,097 Thanks
  • 495 posts
Posted April 21, 2015 - 10:14 PM
Killer input from a lot of cubnutz steering you in the right direction for sure. Kenny in here for you on the PN#'s is too cool as well. My first resto (full restoration) was on a 1250 CC. 11 years later it is still looking pretty good. About 2 years ago I added a rear lift w/spring assist. Removed the mowing deck & hanger and have been working mother earth. Mine had the same issues cosmetic & mechanical. I put way too much funds into it but have never regret it but I wish I did a hydraulic lift conversion. I wish you good luck on your project...at least it's a 1650.
