Not Bad
6 replies to this topic
#1 truck21 OFFLINE
truck21
  • 503 Thanks
  • 286 posts
Posted April 12, 2015 - 03:07 PM
   After sitting in the trailer all winter two out of four fired right up.
    Don
  • MH81, tinbender7, UncleWillie and 4 others have said thanks
#2 HANKG OFFLINE
HANKG
  • 6,307 Thanks
  • 3,421 posts
Posted April 12, 2015 - 03:09 PM
Don your half way there, 50 percent of them not bad. Hank
  • truck21 and tinbender7 have said thanks
#3 propane1 ONLINE
propane1
  • 8,722 Thanks
  • 4,129 posts
Posted April 12, 2015 - 04:06 PM
That's great. I am wondering, were the batteries left in, or taking out ? I take mine out, then give them a slow charge before I put the back in for the new season. Then I expect them to start right up. Some of them are sometimes bad, and take a little cranking before start up. I don't scold them to much. Noel
  • KennyP and tinbender7 have said thanks
#4 truck21 OFFLINE
truck21
  • 503 Thanks
  • 286 posts
Posted April 12, 2015 - 04:46 PM
The batteries were left in, I usually put a charge on mid winter but between snow and real cold that just didn't happen. Both tractors that didn't start turned over just not real strong. I put battery tenders on both of them so I'll check them in a couple days
Don
  • KennyP, oldedeeres and propane1 have said thanks
#5 B10Dave OFFLINE
B10Dave
  • 779 Thanks
  • 348 posts
Posted April 15, 2015 - 07:13 PM
Don; battery tenders are designed to keep a charged battery at peak readiness. They are not designed to rechare a low battery. You will have better results with a proper charger...Dave
#6 HDWildBill OFFLINE
  • 8,975 Thanks
Posted April 15, 2015 - 07:22 PM
Sounds like a pretty good percentage considering the rough winter.
#7 DougT OFFLINE
DougT
    Dog Approved
  • 6,926 Thanks
  • 4,994 posts
Posted April 15, 2015 - 07:39 PM
Don
Actually, the slower a battery is charged the happier it is. From Don's statement of a couple days I'd think he'll be OK. Most maintainers have trickle charge capabiity. A lot i've seen have ran in the 2-5 amp max range depending on the unit.
