Mower Blades
6 replies to this topic
#1 CRFarnsworth OFFLINE
CRFarnsworth
  • 5,178 Thanks
  • 2,256 posts
Posted April 12, 2015 - 01:57 PM
Recently bought a Wheel Horse Commando 8.  Part of the deal included six--3 blade sets of mower blades.  (one 14" & two 12")They were supposed to be for the commando's mower deck.  The commmando's deck uses two 16" blades.  I have no clue what these fit, and was hoping someone on the forum would know.  They are heavy duty and measure 3/16" thick.    One set has a high lift lip the others are much lower. Thanks       Rick
#2 boyscout862 OFFLINE
  • 13,557 Thanks
  • 9,431 posts
Posted April 12, 2015 - 02:32 PM
Measure the blades carefully : length, width, thickness, and center hole(size and shape). There are tables that you go in with the above information and it will tell you part number and what brand uses it. I can't seem to remember where it is. Maybe our Manuals Section. Good Luck, Rick
  • CRFarnsworth said thank you
#3 KC9KAS ONLINE
KC9KAS
  • 5,469 Thanks
  • 4,725 posts
Posted April 12, 2015 - 03:02 PM
Also...someone said blades were measured diagnally, not straight from end to end.
#4 GWest OFFLINE
GWest
  • 557 Thanks
  • 509 posts
Posted April 12, 2015 - 05:24 PM
There are currently 2 different sets of blades available with the 5/8" x 3/4" double-D hole.
8969 kit fits 36" rear discharge deck 5-0622 and others
101335 kit fits 36" side discharge deck 5-0722 and others
There were a couple of sets that turned CCW with a left side discharge but no longer available. These were sharpened on the opposite side.
Garry
#5 CRFarnsworth OFFLINE
CRFarnsworth
  • 5,178 Thanks
  • 2,256 posts
Posted April 12, 2015 - 06:22 PM
Garry
Would the 5-0722 be a deck to fit under a c-120?    I have a c-120 buried in the corner and from reaching under the deck they appear to be the same blade.     Rick
#6 GWest OFFLINE
GWest
  • 557 Thanks
  • 509 posts
Posted April 12, 2015 - 06:27 PM
Yes it is a 1975 model deck for the long frame tractors.
Garry
#7 CRFarnsworth OFFLINE
CRFarnsworth
  • 5,178 Thanks
  • 2,256 posts
Posted April 12, 2015 - 07:11 PM
Great!!   :D I now have 6 extra sets of blades for a G.T. that I don't use. :D
Thanks,  Rick
